cheapmessiah
Did you have to send it to China? Was it expensive?By the way, did you contact Topping or the retailer?
When my A50 was defective, the processing via Shenzenaudio was completely unproblematic...
Funny (not funny) -- the same huge / instant volume jump happened to me within the first hour of using my DX5 on v1.35 and almost melted my LCD-X's AND blew out my ears. I contacted Topping about this immediately and it was apparently not something they had heard about. This was only a week or so ago. Anyways I did update to v1.37 but had to use the D90 DFU since the DX5 DFU for MacOS wasn't working.It's a firmware bug.
Install V1.37
Yes.Did you have to send it to China? Was it expensive?
A rotary encoder is used for the volume control of DX5. This is a mechanical rotary switch. By operating this, an up-down signal is generated and a command is given to the MCU (CPU) that controls the DX5. It is fundamentally different from the analog variable resistors used in DENON / SONY.
- The volume button is OK, but nowhere close to the nice feel that my old DENON/SONY gear has...
I understand that… but lets admit that the Toppings mechanical part of the rotary switch is nowhere close to being “top notch”…A rotary encoder is used for the volume control of DX5. This is a mechanical rotary switch. By operating this, an up-down signal is generated and a command is given to the MCU (CPU) that controls the DX5. It is fundamentally different from the analog variable resistors used in DENON / SONY.
I find that it is common issue for China product that doesn’t have a proper volume knob. My car’s dsd player always failed to register the turn I made. Is there any better option out there?I understand that… but lets admit that the Toppings mechanical part of the rotary switch is nowhere close to being “top notch”…
This and the volume knob alone might steer me towards the JDS EL stack…This is a very good dac for the money but I sure wish the volume level would change when you plug in headphones to where you had it before instead of using the remote to switch to headphone use versus line out use.
Same here, just got my DX5 dead a few minutes ago and come here to check if anyone experienced the same...Hello all,
apparently my DX5 tried to upgrade (without asking), but that did not work. The display alternates between "upgrading...", "upgrade success", "CPLD update" with constant click sounds, and at the end the display says "upgrade failed". Does anyone have an idea how I can get the device working again?
No, it does not have a network interface.But it does not have a Network Interface so how is it happening? could it be the driver on the computer that is doing this?
Glad I didn't attempt the firmware update. Geez. Awful.No, it does not have a network interface.
I unplugged it and placed it closer to my nose. It smells like some components inside got burned.
I believe it was not caused by firmware update. It seems like something inside suddenly broken down, and the device was in a faulty state, causing the random "upgrade" on screen messages.Glad I didn't attempt the firmware update. Geez. Awful.
Well sorry to hear your dac bit the dust.I believe it was not caused by firmware update. It seems like something inside suddenly broken down, and the device was in a faulty state, causing the random "upgrade" on screen messages.
