Topping DX5 Review (DAC & HP Amp)
Rate this product:
    Votes: 16 4.1%
    Votes: 8 2.0%
    Votes: 91 23.2%
    Votes: 277 70.7%
Why are people complaining about the hump? If it were at -200dB they'd still be complaining. 'Cmon guys, the peak of the hump is still equal to the best cases performance of the other DACs.
to be fair, everything about this has long past audible threshold. So by that equation, if we praise a product for it's record-breaking SINAD (which, again, is way above our audibility) we can use the same standard to whine about this ess hump (also above audible area)
I'm very curious how this will compare to the Chord Mojo 2
I am sure many would like to see measurement comparison, however I would doubt if any improvement could be of any real use.
DX5 already have almost everything, and we know Mojo 2 does not have balanced out, display, remote, MQA, etc.
I'm in between this (TOPPING DX5 DAC / AMP) but also in this (Topping EX5 MQA)
I want to drive the genelec 8330 but also the hd 650
Which of the two would you suggest ???
neither. genelec 8330 is better driven by digital in so there's no audio quality loss due to AD.
neither of the products has digital out.
hd650 is easy to drive and their much cheaper product (DX3 Pro+) can do the work fairly well.
I’ve recently been thinking about picking up a amp/DAC for desktop use with headphones.
My main use would be gaming and media consumption (music/movies)
I was looking at separate DAC/Amp stacks with some mix and match components and leaning towards the monolith 887 amp, combined with a gustard x16 DAC.
Would something like the DX5 give me the same end user experience for less money?
This one maybe? https://www.audiosciencereview.com/...ex5-review-dac-and-headphone-amplifier.24341/
Thanks for the replies!
It would appear that I don’t need to spend nearly as much as I was going to.
My understanding is that at a certain point, most of these products will deliver the same quality, and the sound will change based on the headphones being used, and wether you EQ or not.
I realize this is basic, but am I on the right track?
Thanks for giving my some options!
Fair point. But to dismiss the product, as it sounded like others were, on the basis of this "flaw" is asanine.
The DX5 looks great if you only have space for a single-box solution, but for only a bit more, I would consider the E50 + L50 combo. This has, essentially, the same DAC but what I understand to be a more powerful headphone amp with proper balanced output. Depending on your headphone choice, the difference could be beneficial.
Where are the limits of inaudibility defined actually ? Imo human brain is much more sensitive than these analysers.
I don’t think the human hearing apparatus is, but the human brain may well be. It seems highly susceptible to marketing claims and peer pressure.
Thanks! This is exactly the info I was looking for.
The price difference is fairly negligible between the DX5 and E50/L50 stack, enough so that it makes sense to me to lean towards the stack.
I’m relatively new to exploring most of this stuff, and really appreciate the input and feedback
Anyone able to explain what the gain is for the DX5?
On one, it says the gain is 0dB and 12dB, on another 6.7dB and 19dB?
