I have not noticed the same behavior. However, I use Bluetooth.After the update to 1.69, the headphone volume memory does not work correctly. If you turn it off with the rear switch and then turn it on, the headphone volume returns to zero (0 dB), before it remembered the volume. Be careful with headphones.
I cannot replicate this. Give it 5 seconds to save the new volume settings.After the update to 1.69, the headphone volume memory does not work correctly. If you turn it off with the rear switch and then turn it on, the headphone volume returns to zero (0 dB), before it remembered the volume. Be careful with headphones.
if you were listening to music, let's assume (MINUS - 30 dB), after turning off the device and turning it on again, the volume will return to ZERO 0 dB!!! which is very loudI have not noticed the same behavior. However, I use Bluetooth.
Just for clarity it does go your last volume setting, but starts and actually plays sound at zero before lowering?
It did not. I tried it several times. I use it in Preamp mode with USB input. What are your settings?if you were listening to music, let's assume (MINUS - 30 dB), after turning off the device and turning it on again, the volume will return to ZERO 0 dB!!! which is very loud
previous version (1.66) everything worked fine... but they broke itI have tested it in DAC mode and it does indeed set HPA volume to 0 dB after using the switch on the back as @Mario1969 has said. Use Preamp mode, if you are using headphones.
Best to report this to Topping if you could.previous version (1.66) everything worked fine... but they broke it![]()
Does it actually output sound when it is still at 0dB or do the outputs activate only after it returned to the previous setting?if you were listening to music, let's assume (MINUS - 30 dB), after turning off the device and turning it on again, the volume will return to ZERO 0 dB!!! which is very loud
I did it yesterday.Best to report this to Topping if you could.
when turned on again, it activates at 0 -zero- dB... which is the maximum volume , so if you have headphones plugged in... it may damage it as well as your hearing.Does it actually output sound when it is still at 0dB or do the outputs activate only after it returned to the previous setting?
But does it actually have the outputs activated before the volume returns to the previous setting (before it was turned off)?when turned on again, it activates at 0 -zero- dB... which is the maximum volume , so if you have headphones plugged in... it may damage it as well as your hearing.
I updated to version 1.69.
There are no memory issues you mentioned.
It works fine.
Due to the GIF size, I can't make it longer, but
everything works without any memory issues.
http://blog.naver.com/sensationtv/?viewType=pc
.View attachment 477657View attachment 477658
some of you don't understand the problem.... at the beginning I wrote the rear switch....!!!!
