Nezil
I’m not. I’m expecting the same PEQ on both LO outputs.To my knowledge, you can't have two PEQ filters active at the same time, if that's what you're trying to accomplish.
I ordered from Shenzhen audio at 10:56BST on the 10th and asked them about shipping today. They pointed me towards the update (dated to the 11th) on the store page stating that the 1st batch was sold out and that i'd have to wait 30 days for the next batch. I'm in two minds whether to cancel the order, I know I'd just go to the back of the queue to get it somewhere else...
Yeah it happens with relatively high volume for me. The left channel has more DC offset than the rightOK, this is the first time I get HP DC abnormal failure and the sound goes quiet several times
Warning: Political content, a certain someone talks about WINDMILLS
(1.49 firmware installed, so it appears the DC protection does work)
So dc protection works as expected?
Irgendwas ist immer.Perhaps it's a bit too sensitive? I have no idea how to tell how bad that amount of DC offset is...
Quick comparison with SMSL PS200. It plays all of the audio at full volume.Perhaps it's a bit too sensitive? I have no idea how to tell how bad that amount of DC offset is...
Call me crazy but I would deactivate the so-called protection completely if that's a possibility.Quick comparison with SMSL PS200. It plays all of the audio at full volume.
So yes, perhaps too sensitive, but at least headphones and speakers should be safe
They need to tune their software a little bit more. The device needs to trigger and only trigger it when sufficient DC Level holding for long enough time.During the last five or six years I had less than a dozen dc alarms on the ADI-2 DAC. I would rather not listen to these tracks than risking one of my headphones. Not even one of the cheap ones. As more and more audio is produced by clueless people, such a protection is a must have.
Now what about making this switchable? Bad idea in the consumer field. People will turn it off and complain about broken headphones. Seems like a loose loose proposition to me.
Almost totality of consumers listen to stuff without "DC" protection and everything is still fine without hardware catastrophes happening.During the last five or six years I had less than a dozen dc alarms on the ADI-2 DAC. I would rather not listen to these tracks than risking one of my headphones. Not even one of the cheap ones. As more and more audio is produced by clueless people, such a protection is a must have.
That's my point on an earlier reply, what is calculated as DC and what is the appropriate level or mechanism to block it is opinionable. To you the current level might be too much to somebody else is too little, and maybe is DC maybe is something else that triggers as if it's DC, so you block both? What is "sufficient DC level" and "long enough" ? Those must be quantified to a number somehow. As manufacturer you can't make everybody happy and as well you might raise a problem that in reality most likely isn't too serious of a problem in first place. That's for example a field where Apple threads the needle perfectly with their products, delivering an appropriate level of features vs customizations and good experience. Arguably for the sake of having to bring something new every year they're starting to go towards the opposite direction ruining the user experience.They need to tune their software a little bit more. The device needs to trigger and only trigger it when sufficient DC Level holding for long enough time.
Two users, 587 levels of dangerous DC. Depending on volume, headphone/loudspeaker, incompetence of producer, time of day, willingness to take risk.They need to tune their software a little bit more. The device needs to trigger and only trigger it when sufficient DC Level holding for long enough time.
You only know that if you measure used gear advertised as "pristine" (no bad intention to it, they maybe sound like it) only to find out that are way under their specs.Almost totality of consumers listen to stuff without "DC" protection and everything is still fine without hardware catastrophes happening.
cause there's a trend around that helps with meditation (poor, POOR no robust made amps and tweeters Consumers will always blame the manufacturer then, claiming protection was on.I think that having DC protection as an option which defaults to ON would be good compromise. Then user is responsible if they turn it off and DC damages their speakers/headphones.
Or different levels. High-medium-low-offI think that having DC protection as an option which defaults to ON would be good compromise. Then user is responsible if they turn it off and DC damages their speakers/headphones.
