OK, so I'm pretty convinced that the PEQ memory handling still isn't 100%. I cannot get the PEQ setting to track the output, it w
Giving full details of my setup here in case someone else can replicate.
I have my unit set up for two output options, LO ALL and HPA BAL, so these are what I'm toggling between.
I have 3 PEQ memories configured, 1. is for my headphones, and 2 and 3 are for my speakers, with 3 being what I usually use.
When I switch outputs, which I have set to shortcut on the volume push, the PEQ config remains what it was set to for the other input.
What I think is weird, is that I can tell the UI and the EQ itself match, in that they show the EQ that really is being applied, and it is the EQ setting from the other output, but... when I try to change the EQ to the correct one, the first click selects the next memory from where it should have been. I'll try to explain this by going step by step:
- Configure HPA BAL to PEQ 1.
- Switch to LO ALL and configure to PEQ 3.
- Switch to HPA BAL and note that the menu, and the EQ that is actually being applied is PEQ 3.
- Press the button to configure the PEQ and it steps to PEQ 2, not PEQ 1 which would be the logical next step from the menu which displays PEQ 3.
It's like the menu and the PEQ memory itself is not getting applied correctly, but some part of the software thinks it is.
Can anyone else reproduce this?
In addition to this concern, I'm also not certain that the PEQ is being applied to the SE LO output. I have a sub connected to the SE RCAs and my main speakers connected to the Balanced output. I've set the same PEQ on the DX5 II as I had been running on my Mac, and I am getting a lot more bass from the sub than I was previously.
Measurements would confirm this, but again, putting it out there in case anyone else had noticed this.
