Topping DX5 II
I'm probably not, you're right.
Have a nice day!
To do it right though, you need a 64-bit processor, lots of computational power, etc.
Doing 64 bits number math computations “you need a 64-bit processor, lots of computational power, etc.”
Your 30 year old 32 bit i386 architecture PC, for instance, has 64bits (or 80 bits, if double-extended precision is enabled) floating number natively supported by hardware. For floats beyond 80 bits, without hardware support you can also do arbitrary precision computation in software.
There're only 5 parameters involved in a biquad. 5 multiplication and 4 addition/substraction required. can be done in 12 instructions. Easily done in xmos's chip, whose architecture is specifically optimized for such DSP operation.
I bet you never did programming in your life. So if you don’t understand the topic well, please don’t spread disinformation.
Single-precision (32-bit, float)
Max value:
≈ 3.4028235 × 10³⁸
Double-precision (64-bit, double)
Max value:
≈ 1.7976931348623157 × 10³⁰⁸
If you’re in 32-bit world, you can indeed get much higher noise way above 24 bit level.
I don't understand your argument here. I understand 64bits is a lot better than 32bits.
but why 32 bit biquad computation will lead to an error at 24 bit level, if done correctly?
Can you give concrete example?
I give you a practical example: apple silicon M4 max (arm64), 8 bands parametric eq + low and high cut. Floating point needs irrelevant processing power and gets a -70db thd quantization noise. Double precision consumes 6% cpu and has -150db thd. I’m certain the xmos is a great (32 bit) processor, but do we agree no matter how good, we’re in front of technical limitations and magnitudes of power away?
M4 is very good at frequency scheduling so it stays as much idle (staying in the lowest frequency) as possible. When it's in a lower frequency, with same computation the cpu utilization is higher. It also choose to use lower performance cores than the higher. So 6% doesn't really tell anything. I have much lower powered Raspberry Pi 2, and with CamillaDSP built with 64 bits computation, and I can have 40 biquads running in a single core.
Again, JDS mentioned current EQ (12 biquads x 2 channel = 24) only occupies 4 of the 12 DSP cores. I believe their estimation is correct.
Also, modern OS do things different than the XMOS chip. A lot of the computation power is for waiting in the audio queue, which complex lock/mutex mechanism is implemented. If you have a small ring queue, the processor could be very busy. setting a larger queue will significantly reduce your CPU usage at the cost of a longer latency (in the context of music listening, latency is not an issue). Microprocessors on the other hand, is very different.
There's sure a misunderstanding as I'm talking about the bits you need to work with and yes "processor" is not right as it indicates the hardware, my bad.
If you think that sharc processors included in miniDSP for example are plenty, try to do FIR with linear phase filters (IIR and minimum phase is far easier) at around 30Hz, 50Hz, 80Hz . Also search for the taps miniDSP gives and then we're talking about precision.
@Keith_W may be your friend here.
but why 32 bit world will lead to higher noise in 24 bit level, if done correctly? Can you give concrete example?
M4 is very good at frequency scheduling so it stays as much idle (staying in the lowest frequency) as possible. When it's in a lower frequency, with same computation the cpu utilization is higher. So 6% doesn't really tell anything. I have much lower powered Raspberry Pi 2, and with CamillaDSP built with 64 bits computation, and I can have 40 biquads running in a single core.
Sorry I just anticipated your question and updated my original reply just now, I just explained why. (TL;DR truncations make quantization error accumulate in IIR filters since the error feeds back in time into itself)
If you thing that sharc processors included in miniDSP for example are plenty, try to do FIR with linear phase filters (IIR and minimum phase is far easier) at around 30Hz, 50Hz, 80Hz . Also search for the taps miniDSP gives and then we're talking about precision.
You are right at this point: FIR filter is very heavy and requires a lot of computational resources.
However we are talking about Biquad here, which is quite easy. I don't think much power is needed.
But it’s actually true what he shared earlier, IIR or FIR if you increase the sample rate you’re also increasing the computing requirements like the paper said, since you have well… up to 16x the amounts of samples to process.
Also cores don’t matter in this context, it’s just a matter of how much coefficients detail you can handle in different precisions. Uad uses sharc processors and has a lot of high quality classical eq and compressors emulations, it hasn’t touched its code for the past… idk… decade or so and their audio quality is still top tier, I’m not saying good results can’t be accomplished in other ways, but I’m still inclined to believe a sharc processor, even it feels antiquated as approach, is still the way to go at it eventually… I also think perhaps these little dac/amps can also just keep things the way they are, give a little toy eq to the users which is still fairly decent and not bother with it too much.
You are right in that case, but IMHO the filters are not properly implemented. That's why I mentioned "If done correctly".
Topping's error is within 20bit . that's 12 bit precision loss. The real lesson here is to do proper digital filtering, not just copying/pasting code randomly on the internet.
The noise will propagate and accumulate, but it will be greatly mitigated if proper dithering / noise shaping and stable form of Biquad filter structure is used. We know equivalent filters may have entirely different performance when a bad from is used.
Extending to 42-48 bit is an easy and good solution. Many Professional tools are known to produce good result (such as ProTools or TotalMix FX) with such precision.
Although 64bit is not needed in math perspective --- if hardware has that support it would be more efficient to use it. XMOS's official library uses a mixed of 32 and 64 bits in it's biquad sample code. coeff are given in 32 bits. the end result after multiplications/additions are in 64 bits. [*] So if topping is calling the official library instead of reinventing the wheel of their own, they shouldn't get that precision loss.
[*] Official doc says "The IIR algorithm involves multiplication between 32-bit filter coefficients and 32-bit state data producing a 64-bit result for each coefficient and state data pair. Multiplication results are accumulated in a 64-bit accumulator. " The official implementation shows exactly that. Pay attention to the mkmsk, maccs, lsats, and lextract instructions.
Again, my initial argumentto @Sokel is the XMOS chip is powerful enough to do tens of biquad EQs for 192kHz/64bit/2ch using the above implementation. Computation power is not the limitation here, as can be seen from the JDS Elements IV. The above mentioned mkmsk, maccs, lsats, and lextract instructions are specifically created by XMOS to accelerate filter computations in 64 bits space, even though it's a 32 bit processor. Maybe Topping just doesn't know how to do it properly. They are known to produce good spec hardware, but software side is not that strong. In any case, the fault is not on the chip side.
I just got this device but it doesn't seem to save any settings between restarts like colors, gain, etc. I also have to select language each time it starts. Is this normal? I've upgraded to the latest firmware 1.39
This is not normal. How do you turn it on?
It does a factory reset when the volume knob is pressed when the mains power is connected.
Can it be improved? Idk maybe, I guess, if as you said some other product can do better with the same hardware then yes I guess, but having to use 32 bit precision you're still facing a hard cap in a way or the other, personally using float precision I landed pretty much where topping landed, did it sound bad? No it did the job, but having the chance I wanted to achieve the highest quality possible, and I landed at it using 64-bit processing.
I guess people have a choice to make: do I want a better dac/preamp and default to another way to achieve eq if I want the highest quality? Is the included eq still fine for me? (dx5 II) or do I want a better internal eq with a dac/preamp that performs a bit worse and that costs more (element iv)? Do I need the connections of the topping or I can do with the ones of element? What about bluetooth, form factor etc.? I mean to each their own. Personally I'd rather the topping, I'd be undecided only if the element IV worked via usb power.
Btw don't think quantization noise is the only thing that matters in an eq: phase shift, transient, cramping... It's a long list of things.
Yeah weirdly it's not an issue anymore. It happened when I flipped the rear power switch on/off during my first hour testing it but now it seems to save properly. I did have the USB plugged into my PC with the Topping Tune software so maybe some bug happened there after the firmware update? I hadn't put a battery in the remote yet so maybe I accidentally pressed some button on the device but I don't think I did. I'll write another message if I can reproduce it.
How do we know? Are there any measurements I have missed, or a statement by Topping?
I see (maybe well educated) guesses based on hearsays.
He expects similar PEQ quality as D50 III?
Here, by Topping:
Here, by Topping:
Tbh they are right in their reply, people are way overreacting to this. It’s usable, is it SOTA eq? No. Can that quantization noise cause issues? I’d say for a good 80-90% of users is gonna be always inaudible. Want more options and more quality? Use a good software eq, which tbh the common ones that I hear audiophiles use probably aren’t either (or at least I wouldn’t be too sure about it). I’m the first one to say be conservative when using eq, more so if you aren’t using a top quality one, and I probably would never use this since I have no use case for it since I always use dac/preamp hooked on a computer, but is not like your head is gonna explode if you use the peq included in the dac, go ahead, have fun! Enjoy music!
Here, by Topping:
Not sure if "limited" means 20 bits, 32 bits or even 64 bits. All these are limited in a sense.
20 bit is as good as any blind guess, imho.
What I see here is lots of assumptions (speculation), few if any facts.
I doubt it's audible too. Not in the most cases at least.
Proof is people use miniDSP with such problems for many years and although their forums has many complains about it over the years, is not the big majority of users.
As with anything else is our ASR fix to engineering excellency who drives all this talk.
If we were only talking about audible performance 99% of DAC reviews would be needless, so...
Welp, i was gonna sell my D50 III + L30 II combo and buy the new DX5 II, but after having read the past 8-10 pages of this thread i think i'm gonna save myself a headache stay put.
It was gonna be more of a logistical/practicality upgrade anyway rather than an upgrade in sound, i just like the idea of having an all-in-one unit on the desk. Less cables, more clean. And tbh, looks better. But the D50 III + L30 II works fine and sounds great. If it aint broke...
Headache for what? If you want a combo device that’s a great solution, you get basically the same quality of sound in a more convenient form factor, if that’s your goal, go ahead! :)
But it seems like people are getting various bugs and issues that i don't currently have with my current setup.
You are absolutely right. The noise is not audible. But topping's audience buy topping due to engineering excellence.
Otherwise they could get much lower spec but still transparent, cheaper offerings.
To me they made a 125dB Thd+N hardware, but the poor software quality reduce it by 10db.
Why not spend less on a 115dB device then?
In latest reply they disagree this is a problem. So they will never fix it.
Such ignorance is not a good attitude towards product excellency (thus you can see their product is released with a lot of bugs).
It's not hearsay. Your educated guess is wrong. My statements are based on objective facts. Take a look at amir's D50 III review. the noise elevation is 10dB after EQ is on.
