Roland68
It's not as easy as you might think if you want it to work well.I think Topping will eventually come to DAC with 2.1 outputs. But they can sell many other models before they do that. One small upgrade with each new model. And many will feel the need to get the new model.
They know exactly how this game works.
There are now many devices that have integrated 2.1, but hardly any of them work properly. Good implementations only start at four-digit prices, or in inexpensive AVRs or devices like the miniDSP or t.racks from Thomann.
Analog is far too complex. Take a look at the ZinAmp Active Crossover with Phase Correction, for example. It would require two and would have to be completely set up and adjusted. Many people probably fail because of this.
Digital makes much more sense.
But it would only make sense before the D/A conversion. That means a DSP that outputs at least 3-4 channels, is of sufficient quality and powerful enough (computing power). This would then require 3-4 output channels or multiple DAC chips for the DAC.
And this would also have to deliver good measurement values.
Added to this are significantly larger enclosures, just for the connections and additional circuits. A reliable volume control also needs to be integrated.
And the whole thing has to be developed, which isn't exactly cheap.
