- Joined
- May 7, 2020
- Messages
- 147
- Likes
- 268
Yeah that's what I mean. Someone else with a DX5 II and access to Susvara needs to check theirs to see if the same is observed.
The question I answered was about determining full scale not level relative to it.That's for full sine. With music is usually at -30dBFS to -12dBFS for nice recordings.
What we generally see is about 100mV to 300mV (all spectrum combined) tops for nice ones at line level although I have seen as much as 700mV for peaks or hot recordings.
The one we're talking about shows DC near 0dBFS (!) at one channel at the chart:
I thought you would ask for it so here's with REW for double check:The question I answered was about determining full scale not level relative to it.
And the spectrogram for the fun of it:The question I answered was about determining full scale not level relative to it.
This all goes back to measuring 1.7 V DC.I thought you would ask for it so here's with REW for double check:
About -13dBFS at 2Hz (REW's limit), straightly competing with the AC signal.
This whole DC-20Hz energy is usually at down to -60dBFS, lower at nice recordings.
Since in single ended HPA, high gain at 0 dB, 0 dBFS corresponds to 12.1/sqrt(2) = 8.56 V RMS, the 1.7 V DC is at 20*log10(1.7/(12.1/sqrt(2))) = -14.04 dBFS. This fits pretty well with what you got.I tested the whole song. There were several peaks above 1.2 VDC earlier in the song and that largest 1.7 VDC peak was around 2:30 I think.
Coincidently, look at where the scanner finds the largest peak. at 2:23 :was around 2:30 I think.
I suggest reading again ... Your comment infers that all headphones are the same loudness at the same volume setting on the amp
This is a followup to my post #902 about PEQ on the DX5 II. I can confirm that turning off and then back on the DX5 II can shange the stored EQs (6 thru 10). Sometimes only 1 or 2 filters are changed, sometimes all are reset to 0, and there may be other types of changes.
Agree. Seems topping found a way to turn on/off the hp amp circuit. When it’s on the top case is 10 Celsius degrees above the surrounding temperature. When off it’s 7. Both are measured when it’s idle. When driving a load hp amp my produce more heat than that.Those who say it runs hot, is this when it's used as headphone amp? As a DAC it's quite cool, at least for me
I no longer own susvara but I have XK Serene which uses the same drivers as susvara.Yeah that's what I mean. Someone else with a DX5 II and access to Susvara needs to check theirs to see if the same is observed.
It wasn't loud, that's my point though, on the same amp my Aryas are actually loud on low gain at -28dB as a reference comparison. I was playing music, any music but the main test track I first played is Ratchets by HEDEGAARD. The source chain was Blusound Powernode going COAX into the DX5 II > XLR out to the Susvara.No it doesn't. -10dB on High gain is nearly the highest that the device can go. Even if the HPs are 83dB-sensitive, that would still be very loud.
What content are you using to test?
After 2-3 hours, this value can be considered stable. The temperature is definitely within a safe range, so no one needs to worry.Simple temperature test: I measured Topping DX5 II temperature every 30 minutes while playing Clair Obscur: Expedition 33 OST. Output is "HPA SE" i.e. single-ended headphones only, high gain, volume at -10.0dB, Topping DX5 II on table with no heat sources nearby.
Ambient temperature is 25-26°C and in 3 hours Topping DX5 II stabilized to 35.3°C i.e. about 10°C above ambient:
0:30 31.3°C / 1:00 33.4°C / 1:30 34.5°C / 2:00 34.9°C / 2:30 35.2°C / 3:00 35.3°C / 3:30 35.3°C / 4:00 35.3°C
So there is no heat issue (or, single units with a heat issue are faulty somehow).Simple temperature test: I measured Topping DX5 II temperature every 30 minutes while playing Clair Obscur: Expedition 33 OST. Output is "HPA SE" i.e. single-ended headphones only, high gain, volume at -10.0dB, Topping DX5 II on table with no heat sources nearby.
I have an old(ish) analog class-A HPA in my bedroom setup (Lehmann Audio Rhinelander). Never noticed it being abnormally warm despite working in high gain mode. But I haven't measured it and am now tempted to do so "just for fun".Those who worry about this range of temperature - check out any class-A or tube component for fun. Proper heating which is great in winter.
This is not a pure Class A amplifier, but rather a Class AB amplifier, where only a small area runs in Class A and then switches to Class B at higher power.I have an old(ish) analog class-A HPA in my bedroom setup (Lehmann Audio Rhinelander). Never noticed it being abnormally warm despite working in high gain mode. But I haven't measured it and am now tempted to do so "just for fun".
Are you sure it switches to B? I've never read this about this model. The high gain mode of the Rhinelander must be activated by setting two jumpers inside.This is not a pure Class A amplifier, but rather a Class AB amplifier, where only a small area runs in Class A and then switches to Class B at higher power.
