“ you are holding it wrong”Because I tried that Bloc Party track from your link through my D50 III/L50 stack -- L50 was set to Medium gain, 12 o'clock on the volume knob, headphones plugged into the 6.35mm jack, TRS cables used to connect DAC to L50 -- and nothing happened, not even starting at minimum then raising it, going a bit past 12 o'clock. It just kept playing. Is that because the DC protection you have said the L50 possesses isn't working properly or is it simply not being pushed into protection mode under my test conditions? Would that also mean that the DX5 II's DC protection isn't working properly or is it simply not being pushed into protection mode under certain conditions/configurations (JIW mentioned it does and doesn't relay click depending on the parameters)? My understanding is that you have seen evidence that the necessary circuit is there.
Well just kidding. You may use the wrong input of your L50 to trigger that. Remember that a headphone amp has input stage, and may be AC or DC coupled. In terms of L50, inputs may be AC coupled, which means it filtered out the DC in your DAC output physically using a capacitor. So your unit is fine. You may only be able to trigger DC protection using DC coupled inputs.
To correctly trigger it you can try to use DC coupled inputs, or short the capacitors to make AC coupled inputs DC coupled. In this case the DC signal will be fed to the unit, and the unit will guard against it.
DX5II, however, does not have capacitors between dac section and amp section similar to your setup has. So any DC contents in your music will be fed directly to your amp, similar to a DC coupled input case. If DC protection is not implemented, you may burn your headphones.
