JOCoin
- Joined
- Mar 6, 2024
- Messages
- 87
- Likes
- 110
Odd. Just updated mine an hour ago. Hopefully the update didn't cause other issues and that's why they pulled it.link no longer works
I had gotten the update from the DX5 ii download page on their website.My guess they are fixing it being linked on DX9 page as previous mentioned
www.toppingaudio.com
Didn't use that link. Googled DX5 ii and went to the download tab. They temporary took down that link on their DX5 ii page that I used as well.The one I bookmarked clearly stated DX9
front 4.4 and xlr are all balanced. they get twice of voltage swing compared to the SE output.Is the front XLR connection balanced? On the manual it states the rear ones are, but it only lists the 4.4 on the front as being balanced.
Are you sure? Only reason I ask is because I found a good deal on an XLR cable but on my Topping EX5, which has balanced output for the rear XLRs, doesn't for the front. I can't return the cable either.front 4.4 and xlr are all balanced. they get twice of voltage swing compared to the SE output.
I don't really understand what you are talking about... rear XLR is 3 pin, for connecting to studio monitors / amplifiers. front XLR is 4 pin, for balanced headphones. they are not even the same thing.Are you sure? Only reason I ask is because I found a good deal on an XLR cable but on my Topping EX5, which has balanced output for the rear XLRs, doesn't for the front. I can't return the cable either.
The old DX5 only has SE outputs, also via 4-pin XLR.Are you sure? Only reason I ask is because I found a good deal on an XLR cable but on my Topping EX5, which has balanced output for the rear XLRs, doesn't for the front. I can't return the cable either.
However, the power wirh the HE6SE is slightly disappointing. I expected more. There is definitely less power than on the L70. With EQ I have to go all the way to 0dB...
But don't get a wrong impression.
This beauty has a looot of power, and the bass is simply brutal with the HE6SE.
I just listen to very, very loud EDM.
Nevertheless, in my opinion, Topping has created an absolutely sensational product. Especially for the price, it totally degrades the competition!
At 32-64 ohms, the power difference is at least 1 watt, or more.l70 and dx5ii has the similar amount of power for balanced. According to the spec driving a HE6se may only differ 1db between the two devices.
Same issue. My personal opinion is even though the product is pretty attractive at the first glance (price, design and performance), when you actually use it day to day, you'll quickly find the experience is half baked. I got it yesterday and already found a few serious bugs after one day of usage, and none of them are fixed in the 1.39 firmware.I have now installed 1.39, but my EQ profile is still not saved correctly on the device (Windows 11).
1% and 0.1% are cut at almost similar power readings, if you look at their power graph (page 58 of the manual). there's almost no difference.At 32-64 ohms, the power difference is at least 1 watt, or more.
The DX5 II's power is specified at THD+N <1%, while the L70's is specified at THD+N <0.1%, so unfortunately, there are no comparable figures.
Amir's review of the DX5 II will hopefully shed some light on how big the difference actually is.
But nevertheless, the DX5 II has very high power. Not just for the price, and not just for a combo unit.
Was the case with my EX5, I was lucky to buy late and so get one with the latest firmware out of the box.So maybe waiting another month or 1,5 when my delivery happen is a good thing after all![]()
Many products, esp. software and electronics, are thrown at the market like green bananas (they ripe at their customers).
I feel like I've bought a new video game. Now it's time to wait for patches
