ziggurcat
Hello. New member here. Just joined and just purchased my first DAC and headphone kit, DX5II + Hifiman Edition XS. I searched the internet for info on the DAC and found this forum and thread. After reading and skimming through several helpful pages/comments, I was able to learn quite a bit and prompted me to do more research as well. If I understand correctly my serial number for the DAC starts with 26, so I think that means a newer unit that has been updated to protect the short-circuit issue associated with the 4.4mm port? I have no idea when this unit was manufactured, but I did buy new from the Toppings store on Amazon. I do have my XS connected to the 4.4mm port and read the warning not to hot pull or put the cable just in case. So for now I just leave the 4.4mm connected at all times regardless if th unit is powered on or off. Other than keeping that in mind, so far so good for a first few days of exploration and operation.
Chances are if you purchased it recently from the official Topping store on Amazon, you probably have a newer HW iteration. When you receive the DX5 II (if you haven't already), download Topping Tune from the Topping website, boot the software, open the settings window, and see if it recognizes your unit. The relevant information will be on the right-hand side of the settings window (shown above in post #3,473). That's the only way to see which HW version you have, but not everyone has had success with Topping Tune these days (I think they're phasing it out in favour of the newer Home app).
If the installed FW on the device is 2.31 or earlier, then you might not have any trouble checking in Topping Tune. If you update to the latest FW after that, you may not be able to use Topping Tune anymore, but that's sort of moot since they've officially removed the DX5 II from the list of compatible devices anyway. It's just my opinion, but I think the Home app is a lot better than Topping Tune, so you're not really going to miss anything using Home.
