Topping DX5 II
6. What's updated 2.53​
*Fixed: Audio briefly became louder when previewing AutoEQ.
*Fixed: Data could occasionally fail to synchronize between the HOME App, Web Home, and the device when switching inputs or outputs.
*Fixed: When switching C1/C2 scenes, the output option could briefly revert to the previous setting.
*Improved: DC detection algorithm.
*Fixed: Several known issues.
They are quick to push another update. I'm curious if the previous update introduced some new issues.
I have 2 and they still work fine but damn, I'm doing a firmware update every week. It's getting old.
The dawn of agentic AI development tools (Claude Code, etc.) means that software is going to get patched and upgraded (i.e. evolve) at an unprecedented rate until it reaches the next equilibrium (i.e. all the bugs have been fixed and the feature set is complete for the underlying hardware). Or something like that.
If it would do it wireless I would be fine, tired of dragging cords ou, grabbing the laptop and hooking everything up and booting up over and over. I can still tap into both with the android app. I wish that would DL the update and install it to the unit. That would take me less than a minute to start the process and perhaps another minute to finish.
I suspect that the implementation of Bluetooth on these types of device does not support file transfers, so wireless firmware updates may not be as trivial to support as it sounds.
Yeah, I agree. Now it's fixed I can go to bed!
I updated via Home, and it was fine for me. The only weird thing was I could not install the update by selecting "replace" because it kept telling me the app was still in use even though it was not open (the tab in the browser was even closed), and I even manually disconnected the DX5 II from the Home app. I had to go into the activity monitor and force quit. Once I got it to the new version, the v2.53 FW update process worked flawlessly.
Hello folks, I've just bought a DX5 II to replace a DX3 Pro and I'm dismayed by the heavy buzzing noise that's coming out of my speakers when playing PC games (USB input), even when using the headphone output. This is especially weird since I'm using the exact same USB cable and PC I used with the DX3 and had no such issue in the same circumstances. Listening to music while browsing the web is, other than random, infrequent short spurts of electronic noise, problem-free.
What should I do ?
(Both Topping USB driver and firmware are up to date. PEQ and Crossfeed are disabled.)
@Mrtn77 Are your speakers earthed (3 pin power connector), are you using single ended (RCA) connection from the DX5 II to the speakers? If so, there is probably a path to ground from your motherboard to the earth connection on your speakers via the USB and RCA shielding.
Possible solutions:
1. Use a USB Isolator between PC and DX5 II, breaking the path to ground.
2. Switch to optical connection between PC and DX5 II, electrically isolating the DX5 II from the PC.
3. Switch to balanced interconnects between the DX5 II and the speakers (your speakers would be balanced inputs - TRS or XLR), separating the signal from the path to earth.
I went through the same sequence with my Topping D50S after upgrading my speakers to ones with three pin power. I ended up replacing the D50S with an EX5 (to get balanced outputs) and then replaced that with a DX5 II.
Possible solutions:
Thanks. I should have mentioned : the DX5 is hooked to a Yamaha A-S701 through RCA cables (no option for balanced cables on that amp) and both DAC and amp use 3 pin power cables. They're also on the same power strip, the (desktop) PC has its own, which it shares with a computer screen.
I'll try finding a Toslink cable, but would prefer not having to pay for a isolator if I can help it.
What I can't get around is that I didn't have these problems with the DX3 in the exact same setup.
Different devices might connect the USB and RCA shields to the chassis in different ways leading to differences in impedance to ground from your PC to the amplifier/speakers.
The picture of the rear of the A-S701 on Yamaha's UK website shows it with 2 pin power (IEC C18 with no earth pin), but i'd still try an optical connection or cheap ADUM3160 based isolator to see if it solves the issue.
It's probably a ground loop.
You likely didn't have this issue with the DX3 because that has a Class II power supply (no safety earth).
The devices that form the loop are the desktop PC, the DX5 and possibly the screen if it has a 3-pin power supply.
Even though the Yamaha uses the same cable, from the pictures I've seen its power supply only uses 2 pins so that's likely not the culprit.
The solutions are the ones mentioned by @Berwhale
I'm also told that using a single power strip helps, but I wouldn't count on that getting rid of the buzz. :)
Thanks everyone, I'll see about an isolator/optical cable.
There's still one thing I don't get : why is the electronic noise picked up by my speakers, and by my speakers alone, when I'm using the headphone output (I hear nothing amiss through the headphones themselves (Hifiman Edition XS, as it happens)) ?
Sorry to butt in, but the ADUM3160 isn’t sufficient for USB 2.0 High Speed! This chip is only capable of operating at Full-Speed (12 Mbps). However, it will be sufficient if the device you wish to connect complies with the older USB 1.1 / USB 2.0 Full-Speed standard (e.g. older DACs with a resolution of 44.1 kHz / 16-bit or a maximum of 96 kHz / 24-bit, which, according to the manufacturer’s specifications, are limited to 12 Mbps). For higher performance requirements, an isolator based on the ADUM4160 (approx. 26 EUR) or the more advanced ADUM4166 (approx. 60 EUR) is recommended. In my experience, the 4160 works brilliantly with the DX5 II.
Yes, you are correct, but I suggested an ADUM3160 based device because its the cheapest way to test if USB isolation resolves the issue. If one was bothered about running higher than 96/24, then you'd need to Highspeed (480mbps) compatible device.
No apologies needed, I'm very grateful for your input. I can't seem to find an ADUM4160 isolator for such a low price available near me (Paris, France) in a timely fashion. Would a ADUM3165 chip work ? Documentation mentions max speeds of 480Mbps and 3750Vrms of signal attenuation. (I'm woefully tech-illiterate, sorry).
I deleted my post by mistake, but yeah, I believe the issue lies with the unbalanced RCA connection.
The ADuM3165 automatically detects and supports speeds of up to 480 Mbps. This means you can drive even the latest, most demanding asynchronous USB DACs with it; it transmits high-resolution PCM (up to 384kHz/768kHz) and DSD (DSD256/DSD512) signal streams without any restrictions.
Built-in data retiming (Retime / Jitter reduction): This chip not only galvanically isolates the noisy computer ground loop, but also incorporates an internal phase-locked loop (PLL) and signal-cleaning logic. It retimes the incoming ‘noisy’ and jittery USB signal, ensuring that the audio device on the other end receives a much cleaner, more precise digital square-wave signal. In practice, this results in clearer high frequencies, a darker background and more accurate spatial imaging.
A favourite amongst audiophile manufacturers: The more serious, premium USB isolators and ‘purifiers’ (signal conditioners) available on the market (such as the popular LHY Audio UIP and similar products) are, almost without exception, based on this ADuM3165/4165 chip family, supported by external precision clock signals (OCXO).
(Source: Gemini AI)
After trying an ADUM3165 USB isolator and finding it unhelpful, I realized the noise was caused by a RCA cable going from my PC monitor to the Yamaha amp. Removing it caused the noise to stop immediately. I still don't understand why I never got this noise when I had the DX3 installed but the problem is solved regardless. Thanks for the help, everyone.
