New here but just wanted to report some findings about and pre-warn some people to make it easier since I know this device has been really rough overall:Topping releases a new Firmware, supporting TOPPING Home WEB | Web Control Center.
https://www.toppingaudio.com/download/dx5-ii-version-v2-39-firmware-update
6. What's updated
*Added: Web Home support.
*Fixed: Several known issues
1. For me, on the 6.35 mm, certain distortion that popped up when listening to music that peaks are now gone. So it may possibly fix distortion problems overall. Would appreciate if anyone else can also verify this for 4.4 mm
2. Topping Tune, for me at least, is kinda dead, because the past issue of the PEQ on the TOPPING TUNE app not really synchronizing with the device is back, leading me to assume that all my PEQ are gone. BUT, essentially the web home support basically replaces TOPPING TUNE and more, and you will see all your PEQ there. So for those having problem with Topping Tune, check the web home app, I had backups of my EQ profiles anyway but check the home webpage if you wanna check your PEQ, don't necessarily rush to the hardware reset like I did, it was kinda unnecessary.
