Stop reading and start using them instead.Got 2 units 2 months ago, now I'm afraid to use them with all the issues reported ....
They won’t get better aging in the cellar. Pop them open and give them a taste!Got 2 units 2 months ago, now I'm afraid to use them with all the issues reported ....
Used them for sure, had no issues , took the approach to stay on factory bundled firmware and not using eq or any other feature rather than dac amp usability, but I'm just afraid now with all the reportsThey won’t get better aging in the cellar. Pop them open and give them a taste!
Why? It works.Used them for sure, had no issues , took the approach to stay on factory bundled firmware and not using eq or any other feature rather than dac amp usability, but I'm just afraid now with all the reports
Well, it works, but so the ones that reported issues, it worked at firstWhy? It works.
Just don't go fancy with that 4.4mm balanced nonsense that no one needs. Use proper XLR in that case.
That's a life's question you'll need to decide in how to approach.Well, it works, but so the ones that reported issues, it worked at first
You are definitely correct, what is your approach?That's a life's question you'll need to decide in how to approach.
Do you leave your house, or do you stay inside because of all the bad news affecting other people?
My Sennheiser HD660S have been plugged into my DX5 II using the stock 4.4mm balanced cable for 9 months without any issues.Well, it works, but so the ones that reported issues, it worked at first
Well , I switched headphones while the unit is on but never when playing music, that's a rule for me, also what do you say about an extension 4.4 cable to not mess with the port on the device itself ?My Sennheiser HD660S have been plugged into my DX5 II using the stock 4.4mm balanced cable for 9 months without any issues.
My understanding is that the issues with 4.4mm relate to people swapping headphones whilst the unit is on and cables with oversized 4.4mm plugs (the plug on the Sennheiser cable is quite slim and fits nicely in the recess around the 4.4mm socket).
If you are not swapping headphones and your cables fit correctly, then there should be no concern.
My understanding is that the issue relates to a lack of protection against shorts between the conductors for the balanced connection - i.e. it's not a physical problem with the socket itself. This is not an issue for the XLR socket because the conductors do not slide past each other during insertion or extraction. (I'm not sure, but using an XLR to 4.4mm adapter and extracting/inserting at the 4.4mm end could be just as 'bad' as using the 4.4mm socket)Well , I switched headphones while the unit is on but never when playing music, that's a rule for me, also what do you say about an extension 4.4 cable to not mess with the port on the device itself ?
Yes it is.(I'm not sure, but using an XLR to 4.4mm adapter and extracting/inserting at the 4.4mm end could be just as 'bad' as using the 4.4mm socket)
Good idea! Saves wear and tear on the device. It’s what I do. I’d rather wear out a cable then have to deal with a damaged/bad connection port on a device.Well , I switched headphones while the unit is on but never when playing music, that's a rule for me, also what do you say about an extension 4.4 cable to not mess with the port on the device itself ?
Usually DC voltage on output is a hardware failure, otherwise it should be filtered out by internal filters.Just a thought:
Can I protect the unit from overloading caused by DC by applying a steep high-pass filter at 20 Hz.
That's absolutely 100% hardware failure and is by poor design or parts quality. Let me guess, you swapped the phones while device was on?You can install it. It didn't explode, it works! )))
Even the menu settings were intact.
But the left channel still crackles in the bass.
DC on the output is a reasonably common failure mode, such as an output transistor failing short. That's not where it was from in the earlier comments about DC protection tripping though - it was from tracks where the released version contains DC which is arguably a mastering error. In the past most equipment included some sort of DC blocking, whether from having an output capacitor to block it, or a DC servo to get rid of it. Then people started worrying about the cumulative effect of a load of high pass filters, and being DC coupled without a filter became more common. Since the DX5 II has user-configurable filters people can add whatever they want to suit their signal chain, or rely on the protection to do the work.Usually DC voltage on output is a hardware failure, otherwise it should be filtered out by internal filters.
