Is there a way to reduce the output voltage in DAC mode. This feature of 4 or 5 volt option is there on the Topping D50 iii but cannot see it on the DX5
Mailed Topping. Let me see if they can do it with a firmware upgradeThere is no option to choose 4v or 5v mode on the DX5 II.
I did once, they only asked why it was needed basically. I didn't reply again because they still don't seem to understand how to properly do their productsMailed Topping. Let me see if they can do it with a firmware upgrade
It is ridiculous. One can put in preamp mode and attenuate to a lower output, but switching from pure DAC mode to preamp mode when you have another preamp in the chain or active speakers like me (with preamp not defeatable) is a very poor way to implement and will introduce some noise in the chain.I did once, they only asked why it was needed basically. I didn't reply again because they still don't seem to understand how to properly do their products
It's odd, they understood it for D50 III but basically already forgot it to their next product
Right up until you listen level-matched and blind, then the two sound indistinguishableThe D50 iii sounds much more sublime than thr dx5 when D50 is set to 4 volts output.
Yes, they should be very, very, very identical if both are level-matched and don't have the worst filters usedRight up until you listen level-matched and blind, then the two sound indistinguishable![]()
I can put it in preamp mode gain match and listen. As you said it could be indistinguishable.Right up until you listen level-matched and blind, then the two sound indistinguishable![]()
Exactly. And even shut down the LCD panel fully in standby. The backlight is killed but the LCD part can be seen with a very close by flashlightThat said it should not be a big deal for Topping to implent the option via a firmware.
sources.
I'll be bringing it along when I try a couple of open back headphones later this
However my MDA1 has operated without any issue or firmware requirements since new.Don't think MQA costs extra for the consumer these days
FIR is also built in into the chip, it doesn't add addition costs other than implementing them in the firmware, quite easy work
RAW MDA1 is without PEQ and already has a similar price, same DAC..so there's not really much to save here
This is a review and detailed measurements of the SMSL RAW-MDA 1 stereo DAC and headphone amplifier. It was sent to me by SMSL and it is a collaboration with Shenzehenaudio (available elsewhere as well) and is on sale for $246.
The first thing I noticed was the much more polished display. It is also quite responsive to rotary control. If you click it in, you get the standard SMSL menu system that is functional and easy to use, albeit not as pretty. Back panel shows addition of more inputs:
We nicely have internal power supply and balanced outputs -- two...
- amirm
- Forum: Combination Audio DAC and Headphone Amplifiers
MDA1 might be more suitable for those who need more digital inputs. But overall I think DX5 II is the better option
Well yes, I haven't needed for DX5 II either, I've experienced no bugs personally. SMSL tends to not to release much of any firmwares at all, let alone document what the firmwares fix.However my MDA1 has operated without any issue or firmware requirements since new.
The D50 iii sounds much more sublime than thr dx5 when D50 is set to 4 volts output. The reason for getting the dx5 was so that I can have a single box solution for both stereo and headphones. Now looks like I have to shunt out the dx5 and get the Topping A50 iii
Correct! Room acoustics and speaker room interactions are significant factors for loudspeakers. Most(?) listeners do not have acoustically perfect rooms… so a little help from PEQ is great.Ok it makes sense. Thank you both of you.
Why is channel balance typically common with speakers? Is it because of the different acoustics from left to right in a room?
Having speakers at home seems to be significantly more challenging to set up than headphones. I believe placement is crucial, as acoustic considerations also play a role.
PEQ has to be applied judiciously as it can also alter the phase of the signal. I think in DX5, you can apply individually to each channel, meaning there is greater control.Correct! Room acoustics and speaker room interactions are significant factors for loudspeakers. Most(?) listeners do not have acoustically perfect rooms… so a little help from PEQ is great.
Indeed, judiciously applied. I use a WiiM Pro+ to provide room correction and it works great to address my primary room challenges.PEQ has to be applied judiciously as it can also alter the phase of the signal. I think in DX5, you can apply individually to each channel, meaning there is greater control.
