Seems both https://www.toppingaudio.com/downloads and the recent mirror https://topping.audio/download/ are both down now. Anyone able to share the 1.91 FW release?
first one is up for now
Thank you for contacting TOPPING support. We are happy to assist.
Thank you for your suggestion. We will forward this requirement to the R&D department for further evaluation. Currently, you can also see the format of the audio currently playing in the phone's Bluetooth settings.
Maybe an USB isolator between your computer and the Mackie?hi. currently i have dx3pro+ and as output i use Meze 99 classic gen 2 and Mackie mr524.
i would like to switch to dx5 II because of xlr balanced output because my mr524 make a lot of noise. due to faulty spdif output on MB in pc i have to use usb output. and then the mr524 make a lot of noise. so i decided to get dx5 II or k13 R2R. is dx5 II with the latest updates ok?? because i read a lot that there was a problem from the beginning and they fixed a lot of it gradually. will dx5 II or k13 R2R be better for my setup? i mostly play games and listen to music via tidal and spotify. thank you very much for your advice
www.audiosciencereview.com
I replied with the exact same answer. I also informed them that I am not using only a phone.Not with every phone but we already established that ;-)
Speaking of reducing unwanted noise... and apologies in advance if this is obvious to some of you...I replied with the exact same answer. I also informed them that I am not using only a phone.
@Matias there is a cheaper option from JDS Labs. The new Synapse Max
Synapse Max _ Shop JDS LABS
Synapse MAX is a UAC2 compliant galvanic isolator with 10x more output power capacity than Synapse. It's built to eliminate ground loop noise from bus-powered audio interfaces and DACs without compromising USB sampling rates. Its ISOUSB211 enhances performance by cancelling USB signal loss and...jdslabs.com
Je Synapse Labs lepší ako HS02?? What do you think about this https://www.silentpower.tech/produc...qBH0qu5VN_NpvjVYy0RPQdqOQnLrybh1yOGD-ENQEil_zOdpovedal som presne tou istou odpoveďou. Tiež som ich informoval, že nepoužívam len telefón.
@Matias existuje lacnejšia možnosť od JDS Labs. Nový Synapse Max
[URL rozbaliť="true"]https://jdslabs.com/product/synapse-max/[/URL]
if I don't want the usb isolator. and I have to choose between dx5 II and K13 R2R for my mentioned setup. so which one is better?? I read a lot about the dx5 II that it has problems. were the last fw update solved? and the last question that interests me, regarding the chip is there a big difference between dx3pro+ vs dx5 II??? is it worth switching from dx3pro+ to dx5 II?Maybe an USB isolator between your computer and the Mackie?
TOPPING HS02 coming
You can use a USB to SPDIF converter like the SMSL PO100 2024 and use the optical connection.if I don't want the usb isolator. and I have to choose between dx5 II and K13 R2R for my mentioned setup. so which one is better?? I read a lot about the dx5 II that it has problems. were the last fw update solved? and the last question that interests me, regarding the chip is there a big difference between dx3pro+ vs dx5 II??? is it worth switching from dx3pro+ to dx5 II?
Schiit Magni Unity with the mesh DAC is $200 and not plagued with the firmware issues people on this forum are having to troubleshoot every week. No built in PEQ or screen is what you're trading off for the extra money, but even the PEQ is buggy based on some stuff in the other DX5II thread.is there something better I could snatch for that price?
Looks like this one, and the 1.91 prior have been pulled from their site. Any ideas why?DX5 II version V1.93 firmware update
6. What's updated
*Fixed: Several other known issues
Let me say a minor update.
Topping have been updating their website design today. It seems a bit broken at the moment, so maybe the links are missing due this.Looks like this one, and the 1.91 prior have been pulled from their site. Any ideas why?
It's available by direct link, but not from their support website.Isn't 1.91 firmware available anymore?
