Topping DX5 II
Have you done any long listening sessions on that FW?
I'm asking because I'm on a test version of v1.88, and there's an issue that maybe you can verify for me since we're both not on official FWs (it would also help if you encountered the same thing to mention it to them as well). You can PM me to not cause any undue panic about issues people wouldn't be encountering here.
Maybe tonight or tomorrow. I sent you a PM
Topping does not release the new firmware officially ...... it is possible that they have so many fixes that the next one will be version 2.0:)
@Mario1969 My guess is that they will release a 2.0 firmware with numerous fixes before the holidays.
I have a question about the premium remote that comes with the A900. Is it possible to purchase it separately from the device? (I am not talking about the old premium remote version RC22)
Yes, the RC22 remote should be available on its own.
Edit: however, it appears to be a different one that is pictured in the photo you've cited.
I think the RC22 is pretty much the same as the RC21 (which I own), neither of these remotes has the same buttons (and consequently sends the same IR codes) as the newer remote for the DX5 II and other more recent Topping devices.
DX5 II version V1.91 firmware update
6. What's updated​
*Adjustment: Extended the long-press duration for the C1/C2 buttons on the remote control to 3 seconds before triggering the save function.
*Fixed: Resolved the occasional failure to wake up the device via button press when in standby mode.
*Fixed: The occasional unintended wake-up of the device when in standby mode.
*Fixed: Several other known issues.
6. What's updated​
If people download/install this FW, please verify the following issue (since this is officially released):
During the last few weeks, I have had beta/test FW on my DX5 II (a couple of v1.88 FWs and @Bauhaus provided me with the v1.90 beta FW just yesterday), and the last issue I am certain they haven't fixed in this update is an audio hiccup that is reminiscent of the hiccup you may encounter using SPDIF Mode 2. It is an intermittent one, so it requires some close attention to catch. It also only applies to the OPT -- and probably COAX -- input (since those are the two SPDIF inputs). This will not happen using USB or BT inputs. This can probably be tested if you have some kind of output device (CD player/transport, perhaps) to connect to the OPT or COAX inputs, but if you are able to use a USB DDC in between your computer, and DX5 II like I do, I think that would be more ideal (so, @JIW can test in this manner with your SMSL PO100) as I do not know what happens if you do Step 2 below using a CD transport/player. The ideal connection chain in that case would be:
Computer >> USB >> DDC (like a Topping D10s or SMSL PO100/PO100 Pro or some other device that has a USB input/OPT or COAX output) >> TOSLINK or COAX >> DX5 II
Steps I have used to test/reproduce are:
1. Connect a source to the OPT or COAX inputs on the DX5 II, set it to the corresponding input (OPT is probably easier for most people?), and choose any output (I recommend either HPA output because it will be easier to catch the issue)
2. To ensure that the issue triggers, press either the C1 or C2 buttons on the remote (I would advise you to save your settings to either of those preset buttons first so that you don't have to redo everything afterwards). If you're using the same connection as I've cited above, doing this causes the DX5 II to momentarily disconnect from the computer and is an important step to cause the issue to trigger. If you have never touched the SPDIF Mode setting, then this step may be unnecessary, but doing it does result in 100% reproduction IME.
3. Listen to music from any source (either local files or online through Bandcamp)
Because this issue is intermittent, it may take some time before the hiccup occurs, so be patient. I have personally had it happen within 30 seconds, but sometimes up to 5+ minutes before anything happens. I have even had it happen twice within a 4-minute song. It's probably best to select music you are very familiar with to better catch it, but I think the more energetic the music, the more obvious the hiccup.
If you do encounter the hiccup, the "fix" is to go to the SPDIF Mode setting, and switch it back and forth from the default 1 to 2 and back to 1 again (wait for the relay clicking sound each time to be sure) -- hence why this will not happen with the USB or BT inputs. This will not universally "fix" it, though. If you switch to a different output type (for example, switching from HPA BAL to HPA SE or from either HPA to any LO option), you need to do the SPDIF mode switch again. Once it has been done on the chosen output type, the hiccup will no longer occur unless you press the C1/C2 preset buttons on the remote again.
This is what I have observed on the test FW, and I doubt Topping has addressed this since they have expressed some difficulty in reproducing up until yesterday. If people can check this with v1.91, I would like to see if anyone else has this experience. And if it turns out to be a legit bug, I would encourage you to report this to Topping.
After installing the new firmware, unfortunately, everything has to be set up again. I've done it so many times that it went quickly. lThe EQ settings stayed the same, luckily.... I haven't noticed any difference so far.
just checked if there were any audible interruptions... I connected >> CD player to >> T.C. Electronic Finalizer to >> DX5II, it played quite a long time via SPDIF, then via the optical connector, nothing happened.
Did you press the C buttons on the remote?
As an FYI for anyone that was still using 1.72 (and possibly prior) and upgrades to 1.91. While the update does retain the PEQ settings in my case they were all completely incorrect - with very small values.
I wound up doing a factory reset after the update to wipe out the PEQ settings. You aren't losing much because the update wipes out all the device settings anyhow.
It seemed much less buggy re-entering the PEQ. The settings seemed to stick and I didn't have to do it several times to get them to retained. Fingers crossed!
Hi everyone.
I am trying to make the Dx5 ii work with my rme raydat for monitoring o studio speakers and headphones (windows 11). I am completely lost! The rme doesn’t seem to send any signal from adat output to Dx5 via optical cable. I didn’t install any firmware or software yet, just trying to connect the two. I couldn’t find specific information for this particular setup, any help would be really appreciated, thanks.
Hi everyone.
Does DX5 II support the ADAT protocol? I thought it only supports S/PDIF thru coax and optical inputs.
I think not. ADAT is very much an audio interface feature rather than a normal DAC/AMP feature. I think this is just a case of confusing the optical SPDIF port as a universal ADAT/SPDIF connector.
All their website mentions is "USB, Coaxial SPDIF, Optical SPDIF, and Bluetooth inputs". Unless ADAT is explicitly mentioned, it does not support it.
Hi everyone.
On the RME Raydat, it looks like you need to use the 9-pin D-sub connector for SPDIF functionality. The Toslink style SPDIF outputs are all ADAT, of which the DX5 II does not support.
However, it says in the manual that you can use the Coaxial Output (Red RCA plug) with the supplied D-Sub breakout cable.
Updating. Coaxial works great, on the rme I use adat in and out for Cubase , pro tools and YouTube ( multi client) on rme total mix main out is set to SPDF feeding the DX 5 ii. Thanks again for your help!
I am about to buy the Dx5ii, not planning on using PEQ for now, probably ever since I choose my equipment to my liking without considering eq adjustments, are there any issues with random volume jumps or instability issues ? Just plan to use this as a regular dac amp without the bells and whistles, need it only for power.
None I currently experience. Been working great on Windows 11.
