Aryzon
Windows 10 22H2 (updates are blocked)which version of Windows are you using
I will be moving to LTSC soon I think.
In my case, it's exactly the same, even the same version of Windows, but unfortunately Toppin Tune can sometimes give you an unpleasant surprise.
Is it permanently connected to your PC? Fully close topping tune (don’t allow it to default to minimize to the notification area). Power off the device. Power it on. Load topping tune. Upload 10 profiles to the device. Fully close topping tune. Power off the device. Power on the device, load topping tune and check the profiles stored in the device.Interesting to see so many people having issue with DX5 ii. I got mine about a month ago and I am funnily enough not able to update it's firmware as my PC keeps telling me the device doesn't have enough space for the firmware file. So that means I have been using it the way it came out of the box. And I have to say my experience has been flawless. I have used plenty of EQ and moved it between devices. Everything seems to save correctly and apply correct profile under any circumstance with no anomalies.
Maybe for those with issues it's worth to try an older firmware?
I see what you mean now. I had 5 EQ presets. Did the whole power off and on thing and my 5 presets remained. I then added 5 more dummy ones, closed the Tune and rebooted and saw that my 5 dummy presets were gone but the 5 original ones I had remained. Tried again with only 1 extra dummy preset and that one stayed after reboot. Maybe something's wrong when you use all 10 EQ slots?Is it permanently connected to your PC? Fully close topping tune (don’t allow it to default to minimize to the notification area). Power off the device. Power it on. Load topping tune. Upload 10 profiles to the device. Fully close topping tune. Power off the device. Power on the device, load topping tune and check the profiles stored in the device.
As for why you can’t load the firmware are you properly extracting the bin file from the archive? Drag just the bin file onto your desktop. Now drag that file into the device when it is in DFU mode.
I’ve had the same issue with fewer than 10 slots. I just suggested using 10 to maximize the chance of the error.I see what you mean now. I had 5 EQ presets. Did the whole power off and on thing and my 5 presets remained. I then added 5 more dummy ones, closed the Tune and rebooted and saw that my 5 dummy presets were gone but the 5 original ones I had remained. Tried again with only 1 extra dummy preset and that one stayed after reboot. Maybe something's wrong when you use all 10 EQ slots?
Thanks for the heads up.
Topping didn't update the website from the 1.76 firmware. From the archive file itself:Thanks for the heads up.
6. What's updated
• Fixed: The issue that the gain may be amplified by 20dB when switching EQ.
• Fixed: Several other known issues.
This is the setting you need for it.I had read about issue using SPDIF on topping dacs from a TV in these forums before. Something related to the dac expecting cleaner signal and television sets typically outputting less than perfect optical audio. Apparently for earlier models you could request a different version of firmware from support that could make it work reliably.
Now, I noticed DX5II manual have this setting that I attached a picture of, is this related? Would this be okay dac to use with TV (with pc usb use, not tv only)
In my case, the PEQ filters changing to -12dB still happens with 1.78.Thanks for the heads up.
Here is the correct update from the file itself. Thanks @Timbo2
V1.78 (October 27, 2025)
*Fixed: Abnormal sounds after PEQ configuration
*Fixed: Several other known issues
Have you updated Topping Tune? If so, you need to close T T in the bottom right corner tab. Then restart T T. Topping hasn't completely fixed the 12 dB error, which is veryIn my case, the PEQ filters changing to -12dB still happens with 1.78.
1) Create User PEQ - DX5 ii works fine 2) Turn off PC and DX5 ii 3) Turn on both 4) Crackling sound from speakers and PEQ filter show -12dB.
www.toppingaudio.com
For Mac users, Topping Tune 1.09 is finally available:
TOPPING Tune - TOPPING AUDIO
Oh sorry to read that.Sample size of 1 and possible operator error on my part.........
I don't own the relevant Topping gear but downloaded Topping Tune 1.09 for MacOS to look at the user interface.
I could not quit the application and the application would not let me restart or shut down the computer with the application running.
I manually shut down the computer. Upon restart, the app was no longer running and could be moved to Trash for deletion.
There seems to be some people who can write code here, so, a question:
Is there any way to absolutely, fail-safe, hard-code levels and let them be?
Cause we're not talking gear here, gear come and go, we're talking ears and we have to live a lifetime with them.
And if so, can this people with the above skills take it on them and share it with these companies for community's shake?
Thanks in advance!
