Roland68
I'm delighted for you.Nothing wrong with the SMSL RAW MDA1. Works absolutely fine here. The HP-amp has plenty of power to drive my DCA Aeon RTs.
Thank you.I'm delighted for you.
Topping Tune 1.08 is out. Update with the app itself
The update de-selects all display options. You need to select what you want it to show using the toggle switches under the graph.
Lol thanks somehow I missed thatThe update de-selects all display options. You need to select what you want it to show using the toggle switches under the graph.
What you are looking for is probably not loudness (contour), but normalization.
I doubt any consumer DAC/preamp does it, but if so, the manual should state it.
Youtube theoretically has this, but only for a part of their videos...
My defense against such annoyances is a good adblocker (µBlock Origin).
Now its not exactly foolproof but there is a browser plugin for it, its called Sponsorblock, it simply skips the embedded ad portion of the video. Seeing as it does the same thing as an adblocker, you should consider that it hurts the creator's livelyhood in the same way an adblocker does.I have Adguard, and it handles any ads perfectly. But this is a different story. There was an ad for some casino embedded right into the video. And the volume difference between the video and the ad was exactly 2x. It's too much, especially if you watch it at night.
I haven't tried this, but it looks like you can set limiters (on Windows) with Voicemeeter...One could load a limiter VST plugin into a plugin host. That would prevent volume shocks from mid roll ads.
There are some audio interfaces that can host plugins internally (e.g. Merging Anubis, Neumann MT48).
Thanks for the info, I didn't know about this plugin.Now its not exactly foolproof but there is a browser plugin for it, its called Sponsorblock, it simply skips the embedded ad portion of the video. Seeing as it does the same thing as an adblocker, you should consider that it hurts the creator's livelyhood in the same way an adblocker does.
The real crime is the uploader not taking their time to check audio levels for different segments.
Alright, two issues I'm dealing with....one is VERY strange.
So I'm using Optical and USB. I have some slight audio stuttering issues when I first start use optical, but it goes away after a bit or by listening to a youtube video. Apparently a common issue with TV's optical outputs into dacs.
The other...MUCH stranger issue I'm experiencing is when I switch from Optical to USB. Rarely, the audio on USB will sound different. Like, everything would sound heavier; it is EXTREMELY noticeable with male vocals. When I switch back to optical and then back to USB again, it goes back to normal. Making the DX5 II go into standby and then turning it back on also fixes it. It's nothing too problematic, but it is one of the strangest things I've ever experienced with a dac.
Anyone experienced anything similar?
Latest firmware, 1.72. Problem happens when switching from BT back to USB as well.Which firmware version do you have?
