Since you already have an amp, you might just buy a DAC and save some money.No need of a mike in my case.
@amirm did test with the HD650 (not very different com the HD600) and said good things about it (see 1st post of the thread, at the end).How suitable would this be for Sennheiser HD600s? I have an RME Adi-2 which sounds great with these headphones but a second headphone amp/dac could come in handy.
It depends on your headphones.How much difference is there in sound between the regular DX3 Pro and this one DX3 Pro + ?
Is there any DAC AMP combo worth buying in the 500-1000 range?
I have a problem.
I purchased the Signstek Mini USB DAC in order to bridge my PS5 with my new DX3 PRO+ (which works perfectly on PC), since PS5 uses UAC1 audio.
I'm using the same headphones on PC & PS5, they're great.
However, after trying different USB cables, different USB ports on the PS5, Optical & Coaxial cables, there is an on & off stutter happening with the audio, that happens anywhere between every second or so to every 30 or more seconds.
Anyone know what might be causing this?
Interesting, I remember reading about this now. I'm going to order the JDS Labs UAC1 Fallback Cable to connect the PS5 directly to my DAC and see if that works & go from there.I don't know if this model was affected specifically, but there has been talk in various other Topping threads about problems with the S/PDIF receiving abilities of various new Topping products after they switched to a Cirrus chip following the AKM fire.
To you have any other S/PDIF sources or DACs with S/PDIF that you could use to test and isolate the problem?
IMHO it's a marriage made in heaven. I can't believe what a bit over 500. buys these days.Have been waiting for my local dealer to have the DX3pro+ in stock, and they have stock since today. Unit should be here tomorrow. Looking forward to pairing with my Hifiman sundara!
(Hifistudio 79 in the Netherlands)
I doubt it. The manual sucks and after about 30 minutes of head scratching, it occurred to me that the settings can only be accessed when coming to power and that means when plugging in the DC supply which is plugged in to the wall already. Bingo. THe manual could use clarification--in their halfhearted defense, it may be that enough of these devices work the same way, and so it's common knowledge among users familiar with these items--unless of course you are the guy who actually needs to read the manual. Tech manuals--don't get me started.I am too dumb to understand the manual: how do I get into settings/setup mode when only using the knob?
According to this, it should.Do those work with non-JDS DACs?
Hi, some Topping products that use the Xmos XU208 seem to operate in UAC1 if forced through a Fallback cable (DX3Pro confirmed).
Wow, thank you so much. Honestly this is ridiculous - both regarding the phrasing in the manual and the accessibility.I doubt it. The manual sucks and after about 30 minutes of head scratching, it occurred to me that the settings can only be accessed when coming to power and that means when plugging in the DC supply which is plugged in to the wall already. Bingo. THe manual could use clarification--in their halfhearted defense, it may be that enough of these devices work the same way, and so it's common knowledge among users familiar with these items--unless of course you are the guy who actually needs to read the manual. Tech manuals--don't get me started.
So I must say, it did not track at all until it arrived at my doorToday it's shipped out by DHL, but it's not tracking yet... Shall I wait for several days for it to track ?
