WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Hi. Can I use Topping dx3 pro with a Raspberry Pi system? Where I find the drivers? Or must I use a diy dac? In any case, can I listen to CDs?
d s
Thanks and best,
I listen to most of my music on a Pi and a Topping DAC. Pis run Linux and the Linux kernel is mostly made of drivers so you won't need any more! Just connect it via USB. You can listen to CDs if you get a USB CD player but now's a good time to consider using a PC/laptop etc to rip your CDs and store them on a USB hard drive attached to a Pi as a flac file - exactly the same sound quality but the convenience of having all your music accessible via a menu in some software. I use moOde: https://moodeaudio.org/ but there are many alternatives.
Many thanks. The player Is fine. You has right in ripping the CDs, but are there dedicated CD player and burner for Raspberry Pi or can I use a normal burner? By the way, I thought to buy the kit start from the official shop of Raspberry Pi and install Debian Wheezy.
I don't think anyone insisted on ripping CDs. You asked about playing them, and people answered. Ripping (whether just once or every time you play it) is how you get the data off the CD, through the Pi and out to the DAC. If you've got a CD transport you could that directly to the DAC, but that would bypass any EQ you may be doing on the Pi. If you'd prefer to get them as files from Qobuz or wherever that's fine too.
