Topping dx3 pro and filters
davidebond
Italy
Hi. The Topping dx3 pro has 6 filters which were discussed by you elsewhere: https://www.audiosciencereview.com/...l-simple-understanding-topping-dx3-pro.32262/
and: https://addictedtoaudio.com.au/blogs/how-to/how-to-pick-the-best-filter-setting-for-your-dac
Unfortunately, notwithstanding having in my bookshelf the handbook by Nielsen and Chang, I didn't understand. What are the meaning of the filters, explained trivially? They are:
1. sharp roll off filter
2. slow roll off filter
3. short delay sharp roll off filter
4. short delay slow low roll off filter
5. super slow low roll off filter
6. low dispertion short delay filter
Addicted to audio suggested to use a fast roll off or a short roll off with a linear phase, but how can I set a linear phase in the dx3?
Is there one who can explain these filters in a simple manner?
Thanks and best,
davide
JSmith
Algol Perseus
Just pick the default F-3 or F-1 IMO... set and forget. It's very difficult to pick any difference between them all anyway.
To save me typing pages, you will find this article helpful;
JSmith
Calleberg
Sweden
davide
Yes, their main function is to make the "features" list in the marketing material slightly longer, not kidding.:)
And due to such marketing eventually some people may feel they "need" them, and may choose another product if they are not there.
I use F1 or whatever they have chosen to call the sharp standard filter. That is the technically most correct one and the only one needed really.
But don't take my word for it, If you are curious, try them out, it is only the NOS/Filter less settings that can hurt anything.
Hernandezt
Hello, so according the article, for dx3 pro, what is the one to pick, F3 or F 7,
Fast roll off or Fast roll off linear?
bodhi
Can you hear a difference between any of them?
Hernandezt
No, I really can't, just interesting which one in the article is referring to.
