Topping DX1 II DAC & HP Amp Review
Rate this DAC & HP Amp
    Votes: 13 4.5%
    Votes: 13 4.5%
    Votes: 41 14.3%
    Votes: 220 76.7%
I am not saying it's not "good" just not something that **I** ever use.
I have a properly sequenced power up&down routine I am happy to do manually.
But also the power draw of my whole system when not actually playing is not worth worrying about, **for me**. Even when using off grid, which I do for months at a time.
And that one component is not even 1.5% of that little bit of draw.
Finally, on this device, it causes a problem, but that problem is easily solved...
I am not saying these problems should not get fixed.
IN THE MEANTIME I am trying to get a complete enumeration of those problems
and if they all have workarounds
so those of use considering purchasing it "as is" anyway – for the fine SQ + unique feature set, great value proposition – can do so, knowing how to make it work in our systems.
So. If auto-standby is disabled, AND the input sample rate does not vary, are there any further serious systemic issues?
Greetings, fellow sufferers of the same "diagnosis" :D
Can the Topping DX1 II be considered a replacement for the Fiio K7 in terms of reducing the footprint, but without sacrificing quality when listening to IEMs (for this purpose only)?
Given all the identified "issues" with the Topping DX1 II...
So, is it fair to say, everything works as it should, so long as you input a fixed sample rate signal only?
I suppose that's about as fair as saying that a car with a broken air conditioner works exactly as it should, provided you live somewhere cold. :-)
But seriously, the sample-rate switching issue is not the only problem reported with the DX1 II. There have also been reports of occasional distortion, pops and clicks, ground-loop or grounding issues that Amir encountered during testing and couldn't fully resolve, standby problems, and issues with the optical connections.
Of course, not every user experiences all these problems, and some may never encounter any of them.
For users whose requirements happen to match what the DX1 II does well, it's undoubtedly an attractive little DAC, with excellent measured performance, good sound quality and an impressive feature set for the price.
But for another group of users, myself included, some of those features were precisely the reasons for buying it. And when they don't work as expected, the value proposition changes considerably.
So yes, feeding it a constant sample rate may be an effective workaround for one particular problem. But I don't think that justifies saying that "everything works as it should".
There's a difference between a product working properly and a product working properly only if you avoid the conditions that reveal its shortcomings.
I do recognize that difference.
The A/C analogy is a good one. In 60 years of driving, maybe 3 of those years have been in a car with working A/C.
Also in my homes I have not used it since I was a child.
Much of that time has been in places as hot as Bangkok, Australia and otherwise near the equator.
I think it is evil technology a pretty big part of the downfall of our species.
Do you feel the same way about heating? Have you seen the seen the recent estimates for excess mortality across Europe due to the lack of air conditioning?
I've been looking for a replacement of the Creative ZXR for a while, trying to replace it with a small DAC/AMP that has optical out(so I only need one cable out from my PC) and there are very limited options. I bought Creative X5 and the DX1 II last week for this purpose.
After 3 days use of the DX 1 II and I am very happy with it. Here are my experience/settings with it in the 3 days:
- Connected to PC via USB-C to USB-C cable. The DX 1 II is only drawing 2.5w when using optical output and 4.4w when using headphone output.
- Upgraded to newest firmware through web on first day. Settings through the web is very convenient. But it needs to install a driver in order to upgrade the firmware, which I don't feel it is necessary.
- Changed the button single click to cycle output source, and only enabled cycle through headphone/opt out(speaker) two sources. Very convenient to switch between headphone and speaker.
- Windows is set to 32bit 96khz. For all these 3 days, from 8:00am till 12:30am every day, there is no clicking/popping, no distortion at all, including switching between headphone/opt out(speaker) several times a day.
- Only issue I found is after the PC is turned off(usb-c port still delivering power), the DX1 II will go into standby mode as set after 1 minute, but it will wake up and auto switch to OPT input after 10 to 20 minutes. I am not too sure why this happens since there is nothing connects to the OPT IN. I will see if there is any setting in the BIOS that can simply cut the power of USB-C port after PC shuts down.
My 2c after using mine for a while, I've had no issues and its perfect for my use case.
I picked one up to use at home while working. 95% of the time its pugged direct into the work laptop running spotify driving my headphones. I've not had any issues with popping/crackling noises. The unit is good for enabling EQ on a laptop I'm not allowed to freely install any software I like. I've tried it for a few times with RCA out to a set of speakers via an integrated amp, old Rotel some something, and its been good for that as well. With the integrated amp/speaker combo I've also not had any popping noises, I dont have any power amps at home to try it without some form of pre-amp inbetween it and speakers.
Anyway, to add some positivity to this thread I've found it perfect for what I need and I've been very happy with it.
I'm glad to read that many users are happy with the DX1 II. It's a very capable little DAC for the price, and I can understand why people appreciate it.
As long as it's fed a constant sample rate and used through its headphone outputs, or in a setup that doesn't expose the reported issues, many of its shortcomings may simply go unnoticed. The same may be true when using the balanced outputs or connecting it to an integrated amplifier, depending on the system.
That said, I do have some reservations about how closely the published SNR figures reflect what users can actually achieve through the RCA outputs in different real-world configurations.
When the DX1 II is used as a preamp to drive a separate power amplifier, grounding-related noise or hum may become audible. Something similar can happen when connecting it to an integrated amplifier or external headphone amplifier with its volume turned up, leaving volume control to the DAC. Depending on the gain and grounding arrangements, this can make residual noise or hum more noticeable.
Of course, every system is different, and I'm certainly not suggesting that everyone will experience or notice these problems. Still, judging by the reports in this thread, it seems that some of us have encountered similar issues.
I'm not questioning the published measurements themselves, which are impressive. My concern is simply whether that level of performance can be consistently achieved in the various configurations the DX1 II is intended to support.
I really wanted to like this DAC, particularly because its variable line output was exactly what I was looking for. And I do think it offers excellent value for those whose setups work well with it. I just wish the experience had been as trouble-free for the rest of us.
Isn't removing the ground noise one of the main points of using balanced outputs over RCAs? The genetic and inherent issues of RCA connections cannot be the fault of a device or something every review should address.
I'm well aware that RCA connections are more susceptible to interference and ground-loop issues than balanced connections.
Unfortunately, I do not have a balanced headphone amp.
Besides, the DX1 II is a consumer DAC and, as such, I think it's perfectly reasonable to expect its RCA outputs to work properly.
I've connected the DX1 II to several different amplifiers, and the pops and clicks are clearly audible with all of them.
I also own other DACs, including the original DX1, and none of them exhibit the same behaviour through their RCA outputs.
For me, it's a very promising DAC that still feels somewhat unfinished.
Note, this post is not addressed to any one member, answers / reports invited from all present and future owners of the device
I believe the SQ/SINAD issue is well above audible "good enough" across all routing scenarios, my use case does not include volume level control but I don't see an issue there other than "turn SPL off / down before making system changes" ofc.
I see that as a separate issue, and very much system dependent, not unusually attributable to this device specifically.
My only remaining concern here is prevention of any loud pops / crackling artifacts.
Sorry to be a pest, but I continue to want to nail these conditions down explicitly
so the "roll of the dice" aspect can be reduced for those still considering purchasing this unit.
Yes, assume that is the case for all the other use cases.
I believe not required, I am interested in usage of all outputs
given a constant sample rate, either should be OK afaict
how would it make a difference what you are connecting it TO?
If the DX1 II is used to control volume—acting as a preamplifier for a power amplifier or an integrated amplifier (with the latter's volume set to maximum)—a loud popping sound occurs. Reducing the input volume directly on the power or integrated amplifier will diminish the pop originating from the DX1 II; however, this defeats the purpose of using the DX1 II as a preamplifier. Furthermore, when the DX1 II is powered off, it fails to engage muting circuits, resulting in hum being sent to the amplifier. The same occurs when the signal source—such as a CD player—is turned off. All of these issues pertain to the RCA output. Additionally, there are occasional, random dropouts and unexpected pops during playback.
So, input a constant sample rate.
And, with RCA output
(do not use DX1 II as a preamplifier
AND take unit out of the signal chain for bypassing)
Are you a Topping employee?:) That’s the kind of thing they say. "We made a preamplifier, we sell it as a preamplifier—but don't use it as a preamplifier.":)
No, these are horrible and stupid faults, completely inexcusable.
I also think Topping is stupid for discontinuing the D10b model.
BUT IF it fits my use case, those despicable flaws not relevant, I might still buy them
from a seller with good return policies ofc.
There is no comparable price-competitive unit with this specific set of features and high measurements for SQ quality.
I would love for that not to be the case, suggestions welcome!
PS I would only use a device with good loudness contour, automatic / dynamic, for volume level control
