Topping DX1 II DAC & HP Amp Review
Rate this DAC & HP Amp
    Votes: 13 4.5%
    Votes: 13 4.5%
    Votes: 41 14.0%
    Votes: 225 77.1%
The DX5 II produces no pops or clocks for my usage (4.4mm). I don't have any pops or clicks on my DX1 II either but I only ever use the 4.4mm balanced as well. I think the pops and clicks on the latter may have to do with USB drivers.
Pops still happen when you don't use USB.
I am not familiar with the circuit design of either DAC, but I wonder whether there might be a relatively simple explanation for what I am experiencing with the DX1 II.
With balanced outputs, any noise generated by the muting or switching circuitry could potentially be cancelled out. Similarly, if the headphone output, despite being unbalanced, is derived from a differential circuit, this might explain why the pops and clicks are audible only through the RCA line outputs and not through the headphone output.
I also doubt that the USB drivers are responsible for the issue. If I configure Audirvana to convert all audio to a fixed format and sample rate —for example, PCM 192 kHz— there are no pops or clicks. The noise only occurs when the DX1 II itself has to switch between different sample rates or between PCM and DSD.
Go to 1:30 particularly, brace your ears.
From @snadge in another thread, not the only person or video of this.
Reviews are missing this because they don't spend enough time with the device using it normally and at 48kHz.
This is a disaster currently, there needs to be a firmware this week.
Damn that distortion is bad. I was having a similar issue with my IBASSO DC04U which I returned recently after about an hour or 2 it’ll go into straight distortion mode. Sometimes turning off PEQ would help, sometimes not indicating it was a processing, CPU, MCU issue.
Has this issue been fixed on the topping side?
Hi all, new to the forum and this is my first post. I bought one of these and I'm waiting for delivery next week. After reading through this forum, I'm not sure whether to cancel my order or just give it a try. My setup is pretty simple, I just want to connect this DAC to my Mac mini and my Fosi Merak, and listen through my Koss KPH40. So as you can see, nothing fancy or demanding. I like the compact size, and from what I've read, many people who've tried it are happy with the sound quality. However, I'm not sure whether, with such a basic setup, I'll actually notice any difference in sound quality compared to the Merak's internal DAC. Really, I just wanted an external DAC for my Mac mini, no gaming, basically Apple Music. I'd love to hear your thoughts on this.
Hey. You likely won't notice any difference in sound quality, unless you use the EQ function. :)
If you only listen using headphones, the DX1 II would work well for connecting your CD player via the optical input and using the USB connection for your Mac Mini to play Apple Music. The main issue with the DX1 II lies in the unbalanced line outputs, which produce clicks and pops when changing sample rates; however, in my experience, this isn't noticeable when using headphones (I also have a Mac Mini).
Thank you! I think I'm going to take the risk and give it a try, worst case, I can still return it. As I mentioned, all I really want is an external DAC I can connect to my Mac to see if I notice any difference at all with my basic headphones. I'm completely open to the possibility that I won't notice any difference in the end, but I'd rather hear it for myself. What I can say right now is that I do notice a difference, not huge, but real, when comparing songs played from the Merak versus the same songs played through Apple Music on my Mac mini. I think this has less to do with the source itself and more to do with the Merak's internal DAC simply doing a better job than the Mac mini's built-in DAC.
That said, I'm not sure whether my headphones are even capable of revealing a meaningful difference, or if what I'm hearing is just placebo :rolleyes:
So toward a "cookbook" on how to prevent these problems:
They NEVER arise if you avoid the RCA SE line level outputs.
They NEVER arise so long as you feed it a constant sample rate, even when using the RCA SE line level outputs.
Are both those statements true?
I should clarify that I haven’t tested the balanced outputs, so I can’t say whether they exhibit the same behaviour or not. What I can say is that I have not been able to reproduce the problem through the headphone output.
As for the RCA outputs, if I set Audirvana to resample everything to a fixed rate (e.g. PCM 192 kHz), they are silent too. The pops only appear when the DAC actually has to switch sample rates or formats.
So, based strictly on what I’ve tested:
  1. The headphone output appears unaffected.
  2. The RCA outputs appear unaffected as long as the DAC receives a constant sample rate/format.
I’d hesitate to promote either observation from “works on my unit” to a universal law of DX1 II physics. And keeping everything at a fixed sample rate rather defeats one of the reasons for using Audirvana in exclusive mode and sending the DAC the source material at its native rate.
But as a practical workaround for my unit, yes — that seems to be where we are.
I received mine a couple of few days ago and headphone performance has been fine - no clicks/pops even with different sample rates, fed by a wiim mini via optical. I haven't used any other outputs though as I bought this purely for headphones.
They NEVER arise if you avoid the RCA SE line level outputs. (subset, never via HPamp outputs, 2 confirmed)
They NEVER arise so long as you feed it a constant sample rate, even when using the RCA SE line level outputs. (1 confirmed)
That's pretty much the same use I have in mind for mine. What firmware version did it arrive with? Did you apply any firmware update before you started using it? Also, which streaming service do you use most with the WiiM Mini?
I haven't actually checked the firmware yet or tried to update. I mainly use spotify for streaming, plus the mini is networked to a WiiM amp ultra to access flac files (various bit rates) via its usb. I've not had time yet for a long listening session but my initial impressions of the headphone output are very positive.
My DX clicks everytime when seeking timeline on youtube without changing sample rate at single ended output. There is no such problem at 4.4 PO output (or it has much lower level)
I think those observations are useful as a “cookbook” for avoiding the problem, but for me they don’t really address the underlying issue.
One of the main selling points of the DX1 II — and actually the main reason I bought it to replace my original DX1 — is the addition of variable line outputs, allowing it to be used as a DAC/preamp with an external amplifier, headphone amplifier or powered monitors.
Likewise, one of the reasons for using software such as Audirvana is precisely to play different formats and sample rates natively, allowing the DAC to switch accordingly. Resampling everything to a fixed rate certainly appears to prevent the pops, but to me that is a workaround rather than a solution.
So while “avoid the RCA outputs” and “feed the DAC a constant sample rate” may indeed be effective ways of avoiding the problem, they also mean giving up two of the capabilities for which I bought the DX1 II in the first place.
For that reason, I personally don’t consider this a minor issue. If I cannot comfortably use the variable RCA output with my powered monitors or external headphone amplifier while playing music at its native sample rate and format, the DX1 II doesn’t fulfil the purpose for which I purchased it.
I sent an email to Topping support a few days ago describing the problem and asking whether they are aware of it, and whether a firmware fix or other solution might be available. I haven’t received a reply so far.
Unless Topping can provide a firmware fix or another proper solution, I will therefore be returning mine and going back to the original DX1.
Whether this should be called a “failed design” may be a matter of terminology, but from my perspective it certainly looks like a design flaw: a core advertised function of the product cannot be used as intended in my system without introducing an audible artefact.
My DX1 II, running the latest firmware, experiences occasional dropouts and unexpected popping sounds on all outputs—balanced, RCA, and optical—with both the d-1 and d-2 settings when connecting various devices to the optical input. I haven't tested the USB input or the headphone output.
I asked Topping a similar question a few months ago. They replied that I should return the DX1 II. There seem to be only two solutions to the problem: either live with the defect or return the unit.
After reading this message I decided to cancel my order. I'll wait and see in a couple of months if the issue was solved via firmware or if it's a "feature" of the device.
You were lucky that they replied to you. In my case, I haven’t received any response at all, but judging by what you say, I don’t think there’s a solution to the issue—at least not one we can expect from a future firmware update.
Looks like we’ll have to wait for the DX1 III :)
Can someone explain how the separate volume control for different outputs works? And how can I synchronize the volume so it controls all outputs together? Some outputs play quietly and cannot be turned up. It varies—sometimes one output is quiet, other times another one is. A reset didn't help.
