Topping DX1 II DAC & HP Amp Review
Rate this DAC & HP Amp
    Votes: 13 4.5%
    Votes: 13 4.5%
    Votes: 41 14.3%
    Votes: 220 76.7%
I wouldn't expect Topping to give you any answer other than suggesting you use a different preamplifier to eliminate the loud popping sounds or simply return the unit. That is the response I received from Topping's service department.
In fact I don’t have great expectations. I have just written a message to the support. Let’s see what they say.
If things cannot be solved, the return is the only viable solution.
Ale
A few months ago, Topping told me to return the DX1 II. There have been many firmware updates since then, yet the issues persist; it is a hardware fault. Topping might eventually release a new, bug-free hardware revision without making a public announcement. In the meantime, we have no choice but to either live with the defects or return the device. I wouldn't expect Topping to give you any answer other than suggesting you use a different preamplifier to eliminate the loud popping sounds or simply return the unit. That is the response I received from Topping's service departme
after research , the hardware and soft .. its clear there is something with it , topping is a rare maker who have put so much thing ( and bizarre thing ) in firmware , software in this dac.
I think they were to much ambitious with this product
QC before shipping
even beta testing, gather feedback before releasing the finished product
can go a long way to realizing such ambitions.
Reputation of the brand is worth many years of cumulative profits...
I don’t know what type of USB interface they are using but I had previously the same issue with the SMSL SU-1.
I think it’s a problem connected to PLL lock of the internal master clock, so definitely an hardware design issue.
Ale
I would like to know if Topping support has responded to anyone who has reported this issue recently. I find it very frustrating that, after having written twice to explain the problem politely and respectfully, I have received no response at all.
I will keep you posted.
3-4 days for a service response is the maximum acceptable.
Topping would have to admit that the DX1 II is defective. They won't do that. At most, they’ll tell you to lower the sensitivity of your power amplifier or use a different preamplifier to attenuate the loud pops. Furthermore, the occasional random pops and dropouts apparently cannot be fixed via firmware.
It is strange, but the DAC chip ES9039Q2M has a software controlled mute option.
This poses a serious question on Topping’s behaviour towards customers since it is something that could be easily fixed in software by applying few milliseconds delay with mute enabled.
Ale
If the glitch generates downstream to the DAC chip, that’s possible…
Audirvana allows you to mute the DAC when a sample rate change occurs and even set a delay before reactivating the output. Although the delay clearly works, once the muting period has elapsed, the DX1 II still produces a pop when the output is reactivated.
This makes me wonder whether the issue might be related to the analogue output circuitry rather than something occurring purely in the digital domain.
That's interesting, it seems it is the mute circuitry in the DX1 that creates the issue...
My SMSL DL200 only changes sample rate when it detects an incoming signal with the new sample rate. If the DX1 II works the same way, it would make sense that the software mute does nothing to fix the issue...
Yes, that's what a modern DAC usually does.
I’m not sure I understand what you mean. Most modern DACs are able to handle sample-rate changes without producing audible pops or clicks. Depending on the implementation, this can involve sending digital zeros during the transition, muting the analogue output stage, or a combination of both. The analogue muting itself may be implemented using relays or solid-state switching circuits.
So besides Jannox' (likely a faulty unit)
One member has stated that these issues NEVER arise so long as you feed it a constant sample rate, even when using the RCA SE line level outputs.
Can we get more confirmations of this?
My system will be at 44.1 / 48kHz given everything goes through ADAT and I'm not willing to "pay the SMUX tax"
I believe the defective unit affects all users with hardware revision 4. However, not everyone connects it directly to a high-gain power amplifier as a preamplifier—a setup where the loud popping sound becomes a problem. The device apparently lacks any hardware-based output muting. With this configuration, turning off the signal source or the DX1 II itself results in a pop and a persistent hum from the speakers.
Which hardware version exactly are you talking about and where I could find it?
Is it Revision number listed in the drivers?
