Topping DX1 II DAC & HP Amp Review
Rate this DAC & HP Amp
    Votes: 13 4.5%
    Votes: 13 4.5%
    Votes: 41 14.0%
    Votes: 225 77.1%
'This is a DAC that leans towards poise and precision, yet be warned that this can come at the expense of full-blooded thrills. That analytical leaning becomes starkly apparent when we play a DSD64 version of Michael Jackson’s mega-hit Billie Jean. We all know how this one goes – it should sound snappy, propulsive and relentlessly effervescent – but the Topping struggles to express the tune’s vivacious energy as enthusiastically as Jackson originally intended.'
Embarrassing
Hi all, I've been following this thread off and on but have to admit to losing track of the current state of play regarding the various bugs and patches.
I'm strongly considering getting one of these to use as a semi-portable hp amp, paired with a WiiM mini via spdif. I would only be using it for headphone use (not as dac/pre amp) and would most likely use the WiiM for eq. Given this use case, I'd really appreciate if anyone could confirm for me if I'd likely encounter any of the current known bugs/performance issues?
Thanks in advance.
Thanks in advance.
Even after numerous firmware updates, I still experience occasional dropouts on both the analog and optical outputs—specifically when using the optical input. It is not a reliable device. At least, not my unit.
I wish Topping would release a dumber version of this DAC first before adding all the fancy DSP features that seem to be half baked.
Enter the Topping DX1:
Never tested on ASR
That is not "this DAC" despite the name, nor a currently produced model anyway so that specific comparison is a waste of time.
I think the point is, they should focus on the basics implementing new DAC chips, make sure their products work properly AS DACs
before adding all the EQ bells and whistles.
I created a thread for suggestions / discussion of other good-value products in this "DACs with PEQ built in" category
Thankfully the dx1 ii has been stable and performant for me, and I bought it precisely because their EQ abilities are a cut above the rest. No one has come close at the current price point and features.
  • Fiio products are non-starters with their stereo only PEQ and I forget whether their PEQ is supposed to work, or not work, with optical in / optical out / analogue blah blah combos.
  • Wiim is great but in different price category (integrated amp) while Wiim mini is only analogue. Their streamers do not have sub-out until you get to Ultra if I didn't remember wrongly.
  • Minidsp 2x4 is overpriced for those who can make do with 2 channels.
  • And I'm not a programmer, not going to roll my own dacs with raspberries. I'm not THAT into the audio hobby to want to create more work for myself.
If Topping ever allow the ability to create separate PEQ for digital / analogue outputs in the DX1 ii I'm going to disconnect it and hug it to sleep every night.
Wouldn't have considered it at all if the EQ 'bells and whistles' weren't there. Keep running Topping.
So clarifying a "use case formula" to prevent the reported problems from occuring would be super helpful for prospects currently holding back...
Thanks for that. How about headphone output, is that performing OK or also suffering some bugs? I won't be using rca or optical out so just really concerned about performance as a pure headphone amp/dac.
My DX1 II experiences dropouts on the optical input, so the errors likely affect all outputs. I don't use the USB input, so it's possible that one is free of dropouts.
Could it be that the dropouts on the optical input is because your device is going into sleep / standby mode? What's the device?
SMSL PO100 2024 optical output to DX1 II. Option d-2 has random stuttering, but option d-1 is perfectly fine.
Currently using USB input and everything works great.
Ok, switched to using optical input, from my PC into the DX1ii (on mode d-2), RCA out to my amp (couldn't find my 2nd optical cable, right when i need it, as usual). Will report back if I experience any drop-outs or stutters.
This is a VERY underrated tool, we hear frequencies differently, and we can learn about how our hearing works and fix our own personal peaks.
I've found one better, someone shared this tool on reddit with me. It essentially creates a PEQ for your own ears and HRTF.
It will play 44 samples to you and you have to pick if it is quieter, louder or equal in volume. Its actually quiet cool watching it in live time create your PEQ based on your HRTF.
I've actually been struggling with EQ and dealing with listening fatigue and it wasn't until i used this tool i realised how much some iem's or headphones were fatiguing me. I was shocked to see it create almost a -9db correction at 7500hz on a certain pair of headphones. This peak shows up at 8khz on FR graphs but then i learnt about length mode issues and how we all vary and auto EQ is not a good answer most of the time depending on your anatomy.
This tool has done a lot more fine tuning that i ever could have done manually with my own ears. I'll just add it does mostly between 1khz and 12khz and doesn't touch bass nor upper treble. I think this area would be the most sensitive parts on the audio spectrum for a lot of people. Note it may give you more than 10 filters, it may not. You may need to interpolate if you do get more than 10 filters.
Check it out, its made a very very big difference for me. This is the first time in my life i'm experiencing fatigue free audio in my headphones and iem's.
Hi guys, I'm choosing between the dx1 II and the dx5 II. I'm only interested in listening to music on a computer, mostly through a balanced headphone output. My headphones are hifiman edition XV and XS. Is it worth overpaying for the dx5, or do they sound about the same? If there is a difference, could you describe what it is: the stage, the bass, the separation of instruments. I heard that the dx5 II had problems with balanced connectivity, besides, the dx 1 II is powered only by USB, which is a plus for me. But if the dx5 noticeably wins in sound, I'm ready to choose it.
They sound the same. But they both have reliability issues. Glitches, noises, units failing... buy at your own risk. :oops:
