Topping DX1 II DAC & HP Amp Review
Rate this DAC & HP Amp
    Votes: 13 4.5%
    Votes: 13 4.5%
    Votes: 41 14.0%
    Votes: 225 77.1%
When you say on PC on high gain with your 490 Pro you use -30DB what would like be on a a scale of its max volume? Quarter, half, 3 quarters?
-30dB is one eighth of full volume. 12.5%
0dB is max volume and every +10dB means double the playback volume.
Thank you for that explanation, so Matthew4 is able to use their HD490 Pro on balanced high gain at 1/8th full volume on PC, how would that translate over to the PS5 after the low volume bug at -16DB for similar volume?
Is -16Db more like half of full output volume?
Apologies with my weak understanding of these terms, as mentioned just trying to gauge the power output after the PS5 applies it's volume limit.
After upgrading to the latest firmware, the volume control on any output does not work. Not even after setting it via Topping Home or via the remote control. What about it? It seems to be struggling with too many volume settings for different combinations of outputs.
Assuming that the PS5 low volume bug does result in a 16dB drop in volume (I don't know), Matthew4 would have to bump the DX1 II from -30 to -14dB to compensate.
-14dB is equal to 38% of maximum loudness.
-10dB would be exactly half volume, as I've already explained above.
Do a factory reset?
I had a similar problem after upgrading to the latest firmware but by using the "Topping Home" web app to "reset" the dac, everything started working fine. It's probably worth a try.
Yup.
Firmware 23.07 on MacOS ensures that Topping Tune doesn't recognize DX1 II.
That is not my experience.
Mac Mini M4 Pro, MacOS 26.6.2, Topping Tune 1.16, Topping DX1 II firmware 16.07.23.07
MacOS recognition is even better than with older firmware. Functioning fine.
For Windows:
Topping DX1 II - Drivers and Software
Topping Tune is no longer listed.
And it does not function anymore on Windows 10.
For Windows:
Interesting.
I did actually test this (M4), Tune didn't recognize mine. Won't be having another go at it, have dumped Topping Tune and won't be reinstalling.
As DX1 II has been removed from the list of supported Dac/Amps in Tune, I see no point anyway, firmware risk in particular.
Interesting.
I understand. Its such a pity that a nice list of device-options causes so much problems. Immature hardware and software...
I am lucky, I guess. For 5 days in a row DX1 II functions without any issue.
No more firmware updates unless proven good and useful.
I read about iQualize. Very interesting! A real system-level functioning PEQ for MacOS.
The caveat with iQualize is of course not being able to drop the profiles to the Dac, and it is Mac only which breaches my thoughts about using cross platform software wherever possible (I am not using iWork or any downloaded software from Apple). As I only plan to use the dac with mac, it's not a problem for now.
I do find iQualize to be a great solution for MacOS and really like it. In particular the no need to interfer with kernel permits. The choice of file format (json) for saving own profiles isn't ideal for shifting it to PEQ and so on I believe.
I always jiggle a few projects around, will need another plus potentially replacing the desktop DX1 II for one with XLR pre outputs, and having to connect a device not needing it with the vendor/internet beyond firmware updates is something I seek to avoid. Profiles can be fetched from a number of sources by simple downloads or download within an app. Don't need to provide Topping/Brands with access to the Dac for that. All they need for firmware is device (and possibly hardware version) plus firmware version installed, and that can be checked manually and downloaded by user by users.
I will shop around for different options than Topping due to "Home", but many brands seem to prefer access to the Dac.
As an owner of the DX1 II, I thought interesting to share this with everyone who use the Home site for EQ’ing. I’ve only just come across this while on vacation, so haven’t used it myself yet, but looks real handy to make EQ’ing more accurate. It’s an online EQ tool that automatically creates the curves based on what you actually hear. Then just plug the numbers into the Topping Home site. Link to site below video.
Hey! I have Mojo 2 and Moondrop Variations IEMs. I want a simple desktop solution for gaming with IEMs without moving my Mojo around. Can I ask owners opinion on IEMs + gaming performance of this unit? Thanks.
P.S. And I see some firmware issues reports, are those relevant to PC Win 11 → gaming → USB-C → 3.5mm IEMs?
Just got my DX1-II. took about 8-days to arrive, total price was £93.99 (not £92 as mentioned earlier), so much closer to the "standard" shipped-from-china price of $119. Took Shenzen a little longer to get it to me that other Ali sellers but 8-days ish and it's all set up and running great. Solid little unit and I'm fortunately not experiencing any issues on latest firmware and using Topping's driver (ASIO) and Qobuz app (Windows 11). Really happy with it, and while it struggled to get loud with the low-sensitivity Hifiman HE6se v2 (to be expected), it drives my Hifiman Anandas comfortably loud with high-gain at about -20db, and getting very loud beyond -10db. Exceptional value for money.
Much closer? :D
This is a VERY underrated tool, we hear frequencies differently, and we can learn about how our hearing works and fix our own personal peaks.
'This is a DAC that leans towards poise and precision, yet be warned that this can come at the expense of full-blooded thrills. That analytical leaning becomes starkly apparent when we play a DSD64 version of Michael Jackson’s mega-hit Billie Jean. We all know how this one goes – it should sound snappy, propulsive and relentlessly effervescent – but the Topping struggles to express the tune’s vivacious energy as enthusiastically as Jackson originally intended.'
