VientoB
Yeah, I still get it too, but the crackle might be gone.
No...Yeah, I still get it too, but the crackle might be gone.
did you try another USB port? I went from the blue to red (3.2) port on my motherboard and so far I don't have dropouts anymore.Same. I have dropouts/micro-stutter every 5-10 seconds. I'm returning the unit in a couple days.
What do you mean, blue to red? I have tried with USB out from WiiM Ultra streamer and from a Mac.did you try another USB port? I went from the blue to red (3.2) port on my motherboard and so far I don't have dropouts anymore.
Home this helpsWhat do you mean, blue to red? I have tried with USB out from WiiM Ultra streamer and from a Mac.
By the looks of it, Topping Tune is no longer supporting DX1 II as of this version of the firmware.New firmware...
DX1 II V16.07.23.07 Firmware Update - Topping audio
TOPPING, born in 2008, has evolved into a beloved global HIFI brand favored by users worldwide. We firmly believe that higher-quality music playback devices are essential for truly showcasing the allure of music. By investing extensively in professional technology and exceptional industrial...www.toppingaudio.com
2. Release Notes
• Fixed: A popping noise when the device automatically woke from OPT input.
• Fixed: Mute did not work when LO/OPT fixed 0 dB output was enabled and only OPT or LO was selected.
• Fixed: Some known issues.
Yup.
Firmware 23.07 on MacOS ensures that Topping Tune doesn't recognize DX1 II.
Featurewise Home is much better than Tune, no doubt.What can Tune do that Home can't at this point?
I noticed that if you turn off the internet, you can still access local PEQ settings in Home, though you can't access the main 'Home' page.
Note: I accessed it via the Topping Home icon on the Windows desktop (see the 'localhost' address), not from the Topping Home online address.
I do, it's good but seems to have a lower output volume compared to PC.
Using HD490 Pros, balanced cable. On PC w/ high gain, anything past -30dB is extremely loud. On PS5, I have to set it to around -16dB to get the same perceived loudness.
Both PS5 and PC set to 100% OS Volume.
I was hoping the latest firmware update mentioning "Fixed: Low UAC1 recording volume when used with PS5", would fix the output as well, but it didn't.
I overall like the DX1 II. EQ works great. It does get a bit warm though. I do hear pops sometimes but only when adjusting volume and when going from no sound to playing sound. (This is specifically on PS5, I do not get pops on PC when setting the driver to "Always On").
-30dB is one eighth of full volume. 12.5%When you say on PC on high gain with your 490 Pro you use -30DB what would like be on a a scale of its max volume? Quarter, half, 3 quarters?
0dB is max volume and every +10dB means double the playback volume.
The behavior was the same whether using USB or Optical input.did you try another USB port? I went from the blue to red (3.2) port on my motherboard and so far I don't have dropouts anymore.
Assuming that the PS5 low volume bug does result in a 16dB drop in volume (I don't know), Matthew4 would have to bump the DX1 II from -30 to -14dB to compensate.Thank you for that explanation, so Matthew4 is able to use their HD490 Pro on balanced high gain at 1/8th full volume on PC, how would that translate over to the PS5 after the low volume bug at -16DB for similar volume?
Is -16Db more like half of full output volume?
Apologies with my weak understanding of these terms, as mentioned just trying to gauge the power output after the PS5 applies it's volume limit.
Do a factory reset?After upgrading to the latest firmware, the volume control on any output does not work. Not even after setting it via Topping Home or via the remote control. What about it? It seems to be struggling with too many volume settings for different combinations of outputs.
I had a similar problem after upgrading to the latest firmware but by using the "Topping Home" web app to "reset" the dac, everything started working fine. It's probably worth a try.After upgrading to the latest firmware, the volume control on any output does not work. Not even after setting it via Topping Home or via the remote control. What about it? It seems to be struggling with too many volume settings for different combinations of outputs.
