Dimensions. I think they'll settle on the TRRRS 4.4. Very compact and comfortable.How can same brand and manufacturer create such this mess?
TOPPING B4T6-150 (4.4 Balanced to Dual 6.35 TRS 150cm)How to connect this 4.4mm single output to 6.35mm dual input of Topping Mini 300? How can same brand and manufacturer create such this mess?
www.topping.store
Very difficult to find the product. Yes, it’s only $10 on HifigoTOPPING B4T6-150 (4.4 Balanced to Dual 6.35 TRS 150cm)
B4T6-150 - - Topping audio
TOPPING, born in 2008, has evolved into a beloved global HIFI brand favored by users worldwide. We firmly believe that higher-quality music playback devices are essential for truly showcasing the allure of music. By investing extensively in professional technology and exceptional industrial...www.toppingaudio.com
View attachment 543985![]()
TOPPING DX1 II Gaming DAC & Headphone Amplifier
Please note before placing an order: 1. The DX1 II (Black) is expected to be in stock after August 20th.2. Orders will be shipped from China. All costs are included in the price. Shipping time is 7-15 days. To meet the diverse needs of users when using the DX1 II, we now offer three cables...www.topping.store
A Google search with your own words did not work?How to connect this 4.4mm single output to 6.35mm dual input of Topping Mini 300? How can same brand and manufacturer create such this mess?
It’s still uncommon type of cable. Hopefully it will be included in the box for next month shipment because it’s cheap for less than $10A Google search with your own words did not work?
I promise you it won't be.It’s still uncommon type of cable. Hopefully it will be included in the box for next month shipment
due to the exceptionally affordable price level of the DAC, they probably choose do not include the adapter in the box. Not every user will use the DAC line outputs. What is puzzling me is why they decide to put on the market the adapter in a time after the launch, so probably it will take a quite long time to get it, at least in Europe.Very difficult to find the product. Yes, it’s only $10 on Hifigo
It would be a real mess if they try to fit two 6.35mm dual TRS in the back of DV1 II and expect the users to figure out how to combine them for a 4.4mm balanced female. DV1 II is not designed for any pro needs.How to connect this 4.4mm single output to 6.35mm dual input of Topping Mini 300? How can same brand and manufacturer create such this mess?
They made it clear to Bleib that the downloads will arrive later. I just used Topping Home with MacOS 26.x.Apparently Topping doesn't offer downloads anymore for their firmware updates (see attached image).
DX1 II V15.83.22.83 Firmware Update - Topping audio
You now have to go via the web app which forces you to install a helper app. That in itself sucks because nobody needs an extra app running in their system just to update a device occasionally. In any case the helper cannot be installed on macOS Sequoia (see attached image).
I hope they do something about this because if I can't update the firmware the DX1 II is completely useless to me.
Aware of that. Which is why I specified that my experience is with a different version. Topping home not working with 15.x? For the previous firmware I just altered the filename in the download to the new version, but I don't know if they have landed it in their repo yet. Not sure what format Topping is using, unversal or... Rosetta is leaving soon.As mentioned I'm on Sequoia (15.7.7) which is still an actively supported version by Apple.
Why don't you install the firmware from there, then? Mine failed, I unplugged the usb power, left it for a little while to zip off the power, and the 2nd go at it went just fine. Which means Topping has a safety feature for failures during installation....Topping Home works fine (ignoring UX issues) although given it's a web app this depends exclusively on the browser.
Well, it's up on the web now tooBecause to update the firmware Topping Home needs a helper app which cannot be installed in Sequoia.
