Just not without. Active speakers can be connected via an analog balanced cable. Yes, it requires unnecessary conversion, but it's still high quality. In contrast, I haven't seen a modern TV with a copper SPDIF. Only optical. Therefore, removing optical connectors from a modern device is pointless. If Topping had made a standard-sized DAC on a single board, there would have been room for an SPDIF. But Topping has its own vision of the buyers of this device. They opted for two boards with connectors (which is always more difficult and expensive than a single board) just to maintain maximum compactness while maintaining uncompromising sound quality. Perhaps this is a marketing strategy. Perhaps it's an attempt to reach a new audience. Perhaps it's an attempt to avoid accidentally creating a perfect device. Otherwise, there won't be anything else to made
Being away from hifi for a long time thus newbie, and about to get everything new, toslink, USB C, XLR, 4.4 mm and HDMI would be the ones relevant to me. Gave away my vinyl to my younger brother 25+ years ago and decided then I'm not going to revisit. If I had versatility in mind, I would have picked different, but this cute little bugger is for my desk only, will only be connected to a PC/Lin/Mac, a Dab+ with toslink, one headset and one in-ear. The only potential addon beyond that would be small active speakers, probably not. No wifi/BT is indeed a feature for me, thus featurewise it is just about as right as I can get it for MY purposes. The one feature apparently missing of value to me would be PEQ on opt in/opt out, but I presume that combo was designed as a bypass which might be great for others.
Power by USB C (would require their Y split USB for a cellphone, but the music will be available on both, thus no need. With PEQ and no powerbrick are essentials to me, PEQ because I know my preferences differs form the "perfect sound and measurements" norm.
For my next project it is unsuitable, for that I need (preferably) HDMI, optical and USB C (X2 if possible), 220v XLR and sub out.
As for software, Topping has bit of work to do, but that is fully expected and natural as it is early days for them and it takes time to get software perfected, easy to use for all sorts of users, and ideal for all. My take is that they need to integrate the firmware uploader with Tune, and they need to structure themselves better by coordinating Tune updates. For instance, version 1.16 was visible as an update in Tune, without working, whereas it was not visible on their site (one can just change the name of the download file from 1.15 to 1.16). I at least, have had to delete the installed version, download and install the new version for all updates to Topping Tune. I'm on Mac for this, thus it might be working well for Windows.
But they are working on at least 3 different "apps" simultaniously - iPhone/Android, Tune (Mac/Win builds), Home and firmware downloader, and they probably would do better if they got e.g Tune right. Having one working prefectly would induce patience for those waiting for the alternatives.
