It's like USB lost connection and needs to reset.
Thanks, I think unless someone reputable says the issue doesn't exist for them they can be ignored at this point.OK. So, the 48khz has been replicated after about 1h 10-15 minutes in.
Here's a clip, the sound volume in this clip is low, so don't worry about blowing your ears off, but remember to LOWER the volume before you play something else
The massive distorsion occurs from about 0:10 to 0:16
PC (Win11, latest build) USB --> Topping DX1 II (-4dB, V15.69.22.69) ---> Topping MX3s ---> Audioengine A5 ---> Xiaomi 15 Ultra
Sometimes it lasts a lot longer. Sometimes it "just" creates short burts of distortion. There is some variation. But once it starts occurring the only way to fully get rid of it for a while is to do as before, change to optical in and then back to USB. As it is now, I won't use until new firmwares are released.
Ok, I'll do some other sample as rate as well..Thanks, I think unless someone reputable says the issue doesn't exist for them they can be ignored at this point.
Someone also reported this happening at samples rates above 48kHz, I'm not sure if only specific ones or all of them.
The more people who can experience this and report it to Topping, the better.
DX1 II had the same error with previous firmware versions. Topping probably didn't fix this error in the latest firmware version.OK. So, the 48khz has been replicated after about 1h 10-15 minutes in.
As far as I know people haven't had what happens in Bleibs video on the previous firmware, small pops and crackles are not the same issue or as bad of one.DX1 II had the same error with previous firmware versions. Topping probably didn't fix this error in the latest firmware version.
For anyone that looked at that dsdtech ddc for whatever reason, it also measures horribly lol. some guy in the goldensound discord measured it.I'm not sure what this achieves for my use case
Am some guy in question; DSDTECH converter has 6ns RMS jitter, was so bad I actually had to change the frequency scaling setting on the AP to get a stable reading in the audio analysis mode..For anyone that looked at that dsdtech ddc for whatever reason, it also measures horribly lol. some guy in the goldensound discord measured it.
Ty for the infoAm some guy in question; DSDTECH converter has 6ns RMS jitter, was so bad I actually had to change the frequency scaling setting on the AP to get a stable reading in the audio analysis mode..
This unit doesn't have an oscillator in it and is slaved to the USB signal which might explain the poor performance.
For reference an SMSL PO100 has 266ps RMS jitter (typical for spdif), and the Douk U2 (non Pro) has 86ps under same test conditions. PO100 has a single oscillator inside and Douk has three of them.
This is just ridiculous. I guess a potential buyer should wait a few weeks at the very least in order to have a truly non-buggy experienceOK. So, the 48khz has been replicated after about 1h 10-15 minutes in.
That's for an uncommon sample rate. For everyday usage of 44.1 kHz, it is not a problem. It should still be fixed but it is not what you state.This is just ridiculous. I guess a potential buyer should wait a few weeks at the very least in order to have a truly non-buggy experience
Or resample to any frequency above 48 kHz. If it's related to the 48 kHz baseband, you can resample to 88 or 176 kHz. I resample for other reasons, but I've never encountered any grinding noise. Today, I'll try recording it properly: 1 Hz to a 48 kHz WAV file, not to YouTube, and then preview it in an audio editor. If this is a common issue across all devices, I think Topping will find and fix it.That's for an uncommon sample rate. For everyday usage of 44.1 kHz,
Why on earth would you be doing that???Or resample to any frequency above 48 kHz. If it's related to the 48 kHz baseband, you can resample to 88 or 176 kHz.
As I said, this needs to be fixed. But for vast majority of content people play, this is a non-issue.I resample for other reasons, but I've never encountered any grinding noise.
It's a long storyWhy on earth would you be doing that???
Absolutely. In the another thread, I helped those who prefer 48 kHz by identifying and recording the problem. However, for those who, for various reasons, have a 48 kHz signal, you can always resample and avoid problems until this error is fixed.As I said, this needs to be fixed
No offense, but 48 kHz is not uncommon, sir. I use the DX1 II for YouTube, movies, and gaming as well, not just for music. 48 kHz is more of the standard for these kinds of use cases.That's for an uncommon sample rate. For everyday usage of 44.1 kHz, it is not a problem. It should still be fixed but it is not what you state.
This is the price of increased software and system complexity. EQ, streaming, etc. doesn't come for free. Let's not even talk about making an AVR/AVP!
This is quite a common sampling frequency when broadcasting, for example, from Apple Music. There, half of the tracks have a sampling rate of 48kHz. Or broadcast from Android without using UAPP.Это для необычной частоты дискретизации. Для повседневного использования 44,1 кГц это не проблема.
