Topping DX1 II DAC & HP Amp Review (NTTY)
Ok, understood. It would be interesting to test if the results are the same
It doesn't matter where the signal is weakened. I checked it in Camilla DSP. It has an overload counter. Setting this attenuation removes all the overloads I could detect.
V15.92.22.92​
  • Added: Device knob single-click and double-click support for media keys: Play/Pause, Previous Track, Next Track
  • Fixed: An issue with abnormal left and right channels in OPT output
  • Fixed: Some known issues
Optical bug fixed, confirmed
Hmm.... Slightly disappointing, guess can't EQ and still keep it purely digital...
If I remember correctly, other members made it work with newer firmware. I shall update the review with that info. I’ll try myself when I find time.
It's an option in the Advanced Settings on the web interface. You can also choose whether it follows volume control.
In all the time Ive had it, USB C connection to my Windows 11 PC, used with a pair of headphones for gaming , not a single hiccup. Needs to be in high gain to give the power of the DX3 Pro, but then again I dont have a 4.4mm balanced cable to get max power. Im pretty impressed with this unit. If your needs are not great, this would work amazing
One thing I noticed - the optical out is always on and projects a little red square on the surface behind the unit.
like your tv , computer , if he were off it will not detec the opt wire , go to menu and ton of post for support :p
I made it the same size as the Topping interface on purpose, centering the 0dB at 1kHz. You can see that I got exactly what I tuned, nice.
Same from Optical input, by the way (source is a CD Player):
Forgive my simple-minded question, but I just wanted to verify that the Topping DX1 II would enable me to apply PEQ to the optical output of my CD Player, and then route this equalized digital signal through optical output of the DX1 II. Above all else, this is how I'd like to use this device. Thanks for your help clarifying my fuzzy comprehension...
Yes. And easiest to setup is using the Topping Home web app. Search for YouTube reviews maybe on how to use.
If I use optical input from tv and then to headphone output with a right channel only peq does it automatically add headroom for intersample overs?
I appreciate your response. I was uncertain whether PEQ would function on optical-in to optical-out with the DX1 II. (Back in early July there was some discussion on Amirm's review of the DX1 II where NTTY stated he could only get PEQ to work with USB-in to optical-out, but that issue seems to have been resolved.) I wanted to double-check this because a purely optical signal path is all I want to use on the DX1 II (no digital-to-analog conversion, and no amplification). Do I understand correctly that the problems of pops, clicks, and distortion that several users have reported can be avoided if I just use the digital optical signal path for equalization on this DAC? Thanks in advance for assistance with this question...!
So you do not want any format conversion, you are buying a DAC just for the PEQ?
Yes, I'd be buying the DX1 II just for the PEQ. Over the years I have collected literally thousands of Classical Music recordings on CD, and I own so many CDs it would take forever to transfer them to digital files. I want to optimize the frequency response of headphones when using my CD player as the music source, and the simplest way to do that (as far as I can tell) is with hardware like the DX1 II. This Topping DAC/Amp is the least expensive equalizer I've seen that would work in this application. However, I've noticed the frequent comments on ASR documenting the intermittent pops and distortion produced by the DX1 II from its analog outputs, so I'm hoping to avoid those problems by using only its optical signal path, then routing that equalized digital signal to a more reliable DAC/Amp that I already own. For my specific needs, $120 is a modest cost for a good headphone equalizer (especially when compared to similar components that cost much more, and the major cash investment I have already made in my CD library).
see Qudelix-5K also
Thanks for the suggestion. The Qudelix-5K is a versitile dongle with 20-band PEQ, but it lacks an optical input. I want to apply PEQ to the signal from my CD transport, so I need an equalizer like the DX1 II with an optical input that will allow me to make the connection between the 2 devices.
Topping should combine DX1 II and Mini300 into a killer Amp unit with digital inputs similar to SMSL RAW-HA1. It will be pretty much WiiM Amp Pro without the 'smarts'. I think there's a value in that for people who are concerned with the software-based part getting obsolete and/or stop getting updates.
