www.audiosciencereview.com
I add volume reduction to the room correction and after measuring True Peak in modern music, I set not -2..-3, but -4.8 dBDoes anyone know if it would be a good idea to just always leave the volume down on the digital out a bit to account for possible intersample overs, and any idea how much?
I plan on putting the device fully hidden so that would be suboptimal. I'll just drop it 6db to be safe.What I do is set my listening levels on the DAC instead of on the amplifier. This way you don't have to worry about dialing in an exact amount of volume reduction.
Did you mean you didn't enable it, or is this a device limitation (it is unable to apply EQ toslink to toslink)?NOTE: The EQ is inactive from optical input to optical output.
I wonder if this is intended or a bug. I interpreted the product page as meaning the DX1 II could be added inline to a legacy system to add PEQ capabilities. It doesn't explicitly state it will work with optical out but it also doesn't say it won't. For those interested in the functionality, it may be worth asking Topping directly.What I said means it's not active, even if enabled, I recall trying to measure an impact on optical out, but no, nothing.
I take that to mean you can use the DZ1 II as a PEQ DAC rather than merely for PEQ.I wonder if this is intended or a bug. I interpreted the product page as meaning the DX1 II could be added inline to a legacy system to add PEQ capabilities. It doesn't explicitly state it will work with optical out but it also doesn't say it won't. For those interested in the functionality, it may be worth asking Topping directly.
Indeed, this suggests active PEQ on optical output, and I think it works from USB. But from optical input to output no. It might possibly be a bug indeed.I wonder if this is intended or a bug. I interpreted the product page as meaning the DX1 II could be added inline to a legacy system to add PEQ capabilities. It doesn't explicitly state it will work with optical out but it also doesn't say it won't. For those interested in the functionality, it may be worth asking Topping directly.
The fact there are multiple interpretations and none of us can really say for sure, perhaps it's a good indication the advertising could be clearer. However, my point was more that if anyone was interested in/hoping for PEQ being applied to optical out, and I'm not one of those people, they might want to clarify with Topping. You never know, it might be either intended to work or Topping might add it later on.Yeah, I think it means that if a source (like a CD player) has an optical out then you can link it to the optical input on the Topping and access the DSP (routed to the analog outs). Some older topping (D50 III I think?) didn't offer the option to use DSP from optical, only USB. So that's why they're advertising the feature (I think).
