Topping DX1 II DAC & HP Amp Review (NTTY)
Almost 10 years have passed, and Topping continues to manufacture devices that are perfect for measurements but garbage for consumer use.
That noise was present before. It also happens when the sample rate changes, I wish Topping fix this ASAP.
Also my DX1 used as preamp is clicking at every sample rate change. As I mentioned on Amirm’s thread about same device here on ASR, I wrote a request through Topping’s support and their response has been shameful (two responses, one bad the second even worse).
Very annoying. What a pity for a device otherwise with stellar performances and a rich and interesting set of features.
End of my experience with the DX1, returned to Amazon. Period.
The DX1 II has a pronounced treble roll-off. I'm using the relatively easy to drive Focal Elears via the 4.4mm output. The roll-off is very obvious when compared to my DX5 II and even the Qudelix T1. Disappointed. I expected some loss of dynamics because its USB powered compared to the DX5 II, but didn't expect any treble loss. I did a full reset, played with the filters, etc., but nothing fixed it. I suspect its just how the headphone amp circuit is designed.
Hello everyone.
Is this dac/amp recommended for planar headphones such as the Hifiman Edition XS , with possible EQ in mind? It will be used on my PC , connected to my motherboard. Could there be alternative options?
Thanks a lot!
Hello everyone.
• 4.4mm Balanced Output: 1000mW x 2 @ 32Ω / 230mW x 2 @ 300Ω
• 3.5mm Single-Ended Output: 510mW to 800mW @ 32Ω
So yes, but for higher volume use a balanced adapter
Be sure the USB feeds it good power / current
