Topping DM7 8-Channel DAC Review
Rate this DAC:
    Votes: 7 2.1%
    Votes: 19 5.7%
  • 3. Fine (happy panther
    Votes: 56 16.7%
    Votes: 254 75.6%
I'm struggling to understand how this device can be used in a multichannel surround system. Can it do anything that can or cannot be done by an AVR or surround processor? Is there software that allows it to be used as a DSP incorporating high-pass and low-pass filters, PEQ, channel levels, phase and delay so that it acts like a miniDSP or Dayton Audio DSP-408 but with digital input? How do I get a Dolby Digital 7.1 stream into it? Can it decode that? (Obviously it doesn't support Dolby Atmos in any way, as far as I can see.)
I see this as a device for HTPC's. Topping's marketing should be trying to reach out to users of software like JRiver, etc.
The big question - does it play nice with Linux ?
What kernel is required/test @JohnYang1997 ?
Yeh Focusite is class compliant too.
Just ask anyone who uses it on Linux for multichannel, if it works.
It doesn't.
So class compliant almost means nothing to me. from practical experience
We need to know what Linux kernel version was tested (if tested) for 8 channel support.
Or wait for someone to buy and test
^^/ Do Topping ever do it?
...btw, how does it [multichannel] work with Apple device/OS?
Interesting although I have no use for it if it can't decode home cinema audio codecs :)
Alternatively, if you want to keep a fully balanced audio chain and DSP each channel, I believe you could use software like JRiver (which you can optionally integrate with Dirac Live Multichannel).
This seems like a more sensible option. First, have a 120 SINAD DAC convert to analog, and then go back into a much lower quality ADC and DAC, just to get some Dirac and filtering? That is just a waste of money and engineering.
Suppose I have the above configuration:
1) USB connected to PC and running Foobar2000
2) connection to active speakers as above
Does Foobar 2000 have channel assignment such as above or similar (the numbers above are just for reference)? What about SW cutoff frequency setting? Does Foobar2000 have cutoff freq setting?
Schenzen Audio:
Do they actually mean it needs a computer attached, as NOT shown in their graphic? So $600 for the unit and $1,500 for a laptop. Surely cheaper and more practical to just get an AVR receiver and you also get a proper remote?
For all those lamenting the lack of physical inputs if you are running CamillaDSP it is very easy to add a SPDIF input with a device like this -> https://hifimediy.com/product/s2-digi/. Just set the hifimediy as your capture device and the DM7 as your playback device and enable async resampling and rate adjust and CamillaDSP will bridge the clock domains. Poor man’s Okto at half the price.
Michael
Is decoding DD+ 5.1 over optical a thing that is out in the open in 2022?
Might be an affordable option for someone that just wants 5.1
YES YES YES SO MUCH YES OH MY GOD THANK YOU TOPPING!
I've been pestering Topping DAC reviews lately with cynism because I never expected them to deliver. Now here it is, a nice multichannel DAC for a sane price. Thank you so so so much! This thing is a sure buy from me!
Edit: Okay, I calmed down a bit.
Before I buy - is this thing easy to use as in I just enable 7.1 in Windows 10 for this DAC and channels are working fine or is some routing necessary? I just need 4.0.
I am really interested in this little gadget but I am wondering if this is really the needed nudge to ditch my AVR and just go with PC, EAPO and this multichannel DAC. But this would make gaming consoles and my Nvidia Shield unusable due to nonexistent HDMI or optical input. No connection to TV possible.
Though maybe I'll get a surprise and this DAC would be recognized by LG TVs. An external USB-network plug already worked this way.
Schenzen Audio:
Unless you already have a free laptop or computer lying around, in which case it's cheaper to go the HTPC route.
Modern AVRs support more codecs, such as object-based (aka height support), which HTPCs cannot (or at least not without spending a LOT of licensing money). That's is their primary technical differentiator from a PC based system. The customer has to decide whether that's worth it, because object-based encodings aren't that common. In fact, a nontrivial player in the space, Auro 3d, recently declared bankruptcy.
A balanced 8 outputs USB DAC with SOTA performance, this is an unexpected surprise! :D
One question: is it free from any form of noise/click/thumb on its outputs (even slight) in any circumstances? (PC on/off, USB plug/unplug, sample rate change, etc.)
So...
With the assumption it works with Linux ALSA, what Linux*** playback software would:
1- take a stereo input and create another set of stereo channels (i.e. I end up with 2 x Left and 2 x Right)
2- allow me to apply low and high pass filters on each of my now four channels (or at least independently to each L/R pair as a set)
3- allow me to apply PEQ on each of my now four channels (or at least independently to each L/R pair as a set)
4- pass this over USB onto this DAC so I use 4 of its 8 outputs
Thanks,
Peter
*** or worst case win10 software if I want to slum it
Does it have individual channel volume control?
Or a simple volume control for everything?Can't find this piece of info which is crucial for some applications.
No chance of even basic DSP?
It seems it does not have, all levels should be set in software before it.
Considering the negative comments are mainly about what it doesn't do and is not meant to do in the first place, they're actually compliments in reverse.
Kudos to Topping for a featuritis-free device with corresponding attractive price point.
To justify my comments:
It's all about comparison,a device like this has very certain functions and the similar Okto has put the level quite high.
For 600 euro someone can buy 8 transparent channels even in the form of 4 dac's.
Everything is about the case of use and individual channel VC is the very least.
Indeed. Another response helping me to cope here.
4 dacs can "work," but consider that:
- it will be 4x the devices
- many more wires and power outlets
- may require much more initial configuration on the computer
- I've read that there can be sync issues between clocks when using multiple DACs
