Topping DM7 8-Channel DAC Review
Rate this DAC:
    Votes: 7 2.2%
    Votes: 18 5.6%
  • 3. Fine (happy panther
    Votes: 53 16.4%
    Votes: 246 75.9%
sarumbear
You might get a bunch more even order distortion since it won't be canceling any longer, but that's not exactly the biggest problem.
What is not cancelling?
sarumbear
Topping D10 Balanced can not be converted to single ended. Maybe you can tell us why since you seem to know everything?
Who says that it can’t be converted, what is the issue they have?
I cannot imagine a scenario where a balanced output cannot be connected to a balance input?
Kal Rubinson
Industry Insider
NYC
I cannot see what can be the problem. Can you?
1. If the naive user employs a mono TS plug, it will short the output.
2. At least one manufacturer has cautioned against loading one leg of the output while leaving the other unloaded citing possible problems for the output stage.
In general, I like to err towards caution when advising apparently naive users.
tifune
Link please.
I can see why some people think it's a shim for upstream AVRs, but when I enable it + upmixer I get "7.1" playback. It's somewhat strange, my Denon shows Dolby Surround on all channels but I'm getting front, front height, surround back, and rear height. No center or surround channels. Same thing that happens using Atmos via Amazon or Apple Windows apps
You probably didn't read what the app is actually doing, did you?
I don't need the app for that, so I'm not sure what the purpose of Atmos for HT would be in that case
sarumbear
Use a proper cable with a matching plug on both ends. Simples!
In my mind such an advise is similar to saying don’t plug a 110V device to 220V mains socket.
sarumbear
Maybe why some people are questioning the DM-7 having only balanced outputs?View attachment 218137
That is not saying you can’t connect the D10 output to unbalanced input. It simply says don’t use an adapter. Isn’t that clear English?
Veri
That's.. not really what is meant. A great many cables with "matching" XLR/RCA or TRS/RCA plugs will not work properly (if sleeve and ring connections are tied) and the D10 balanced will perform at less than 90dB SINAD as shown by archimago on his blog.
So having the connector correspond hardly means it is a good idea to use a balanced output to connect to an unbalanced input. Usually it will hamper performance and harmonic distortion levels.
voodooless
Netherlands
Isn’t that an obviously stupid setup? Your grounding one of the outputs, basically overdriving one side of the balanced pair. It’s like putting the accelerator down on your car while braking. That can only leed to suffering and agony. Just terminate with something like 10k. Should be fine.
sarumbear
No scenario requires a balanced (TRS) to unbalanced (RCA) cable to have the tip and the sleeve of the TRS plug tied together. That’s not a balanced to unbalance cable, it is a mono (RCA) to stereo (TRS) cable. One can’t complain when they use the wrong cable. Or should claim that a connection is not possible. This is audiophile 101.
Sokel
That's what Ice Power recommends,that would be ring and sleeve together if it was TRS on the side of the amp.
I have never seen tip and sleeve together,you're right.
sarumbear
That schematic is showing an unbalanced to balanced connection. We are talking the opposite. I thought I made that very clear in my post but obviously I failed.
However, why the output pins on the schematic are labelled as IN I have no idea?
Sokel
You're right,I stand corrected.
Whoareyou
Chicago
Of course, the balanced signal can be converted to an unbalanced one if done properly, such as with a transformer or an active circuit. What you are asking, I think, is can I use an adapter that takes one side of the balanced output and uses it as an unbalanced one.
Thanks Kal.... You've clarified my (apparently) clumsily worded question / comment.
A little more info.
I just received reply from Topping support who said they would not recommend using a balanced to unbalanced connection with this DAC. I guess it's up to everyone to decide for themselves exactly what "recommend" means.
I guess it should work :)
Labjr
A little more info.
That's unfortunate. I doubt they're going to make a single-ended version?
dualazmak
Kal Rubinson
Industry Insider
NYC
Probably. However, the original reply was not addressed to you.
