Veri
- Joined
- Feb 6, 2018
- Messages
- 9,597
- Likes
- 12,039
No need to make four posts in a row, this clutters up the thread for everyone it isn't just about you. Anyway you want comparisons using drivers from other manufacturers? That is not even possible, the USB driver is signed for a specific manufacturer/producer in the form of a vendor ID.
I believe John means to tell you that you are being unreasonable and/or don't really know entirely what you're talking about as in the USB example. Just be friendly and polite in what you're trying to determine, and people will look into it and even measure it I've seen nothing but good intentions in the other posts. Your current behaviour is rather aggressive and blameful. Even in top of the line products some devices fail, if the pop noise is way too loud to be normal I would suggest requesting a return and refund. That should be a pretty easy solution...
