Topping D90LE - SINAD measurement (with E1DA Cosmos APU Notch)
R
Rja4000
Liège, Belgium
Do you have an AP at hand ?
How wide is the fundamental range on the AP ?
IVX
South of China, SHZ area, - Слава Україні
I posted the screenshot, you can see it, or do you need BW at -3db?
IVX
Of course, the situation I've simulated is way nonrealistic because the only noise was taken into account but distortions were artificially set to zero. However, that simulation well shows a noticeable difference AP vs REW, and nearly no difference AP vs Matlab. With more or less real signals, the difference is less.
R
Rja4000
Liège, Belgium
After some "tuning",
I can now consistently reproduce REW "AES-17 2015 standard notch" results with Virtins Multi-Instrument 3.9.6.2
Here is a comparison of different SINAD measurement methods:
It's all for the RME ADI-2 Pro fs R
I measure the DAC, both channel merged in Mono (my usual setup for measurements) for the 13dBu range
The RME allows to go over 0dBFS, so I dialed in +2.5dB on the volume knob, for an output range of 15.5dBu (approx)
Except for the Red measurement, the ADC is the RME itself, in AutoRef mode (range switches automatically from +4dBu to 13, 19 and 24dBu)
The Black plot is with the APU notch (+6dB), with the AES-17 2015 notch compensation (fundamental computed on 1 full octave, as in REW)
The Blue plot is the same measurement, but using the standard SINAD measurement from Multi-Instrument (which measures on a much narrower range)
We see that there is a constant noise penalty of around 2.8dB with the APU notch in the loop.
The Orange and Pink plots are measured without the APU Notch (direct from DAC to ADC)
Interestingly, they are pretty much identical (the measurement of the fundamental over 1 octave is only important if you use the APU Notch)
Also, we see that the noise at low level is exactly matching the noise with the APU notch and the AES-17 1 octave fundamental.
That gives me good confidence that we can get accurate results this way.
Finally, the Red plot is measured by connecting directly from the DAC to the E1DA Cosmos ADC in 4.5V range.
Note that the noise is higher (we could get lower noise with another range, but then we'd saturate at the top level)
Also note that the distortion starts lower in Voltage and that DAC output is then limited, due to the low input impedance of the E1DA ADC.
R
Rja4000
Liège, Belgium
So,
here is theTopping D90LE SINAD in 4V Mono
With corresponding plot vs level
Jimster480
Tampa Bay
Explained above. I use this method for measurements.
Yes but are you merging it yourself? Meaning you are feeding the same signal to both channels and then doing an external merge? Or is there some mono mode?
I'm going to assume that you are doing an external merge because you mentioned "XLR Output"
pma
Prague
@Rja4000 , why don’t you switch Y-axis scale to dBr, to get the peak at 0dB? To the unexperienced reader, the spectrum plots might seem overoptimistic.
R
Rja4000
Liège, Belgium
Fair point
Here we go
NB: One difference with the initial measurements in this thread is that I now use a test signal at 997Hz, as per AES-17.
The main difference is that the 20th harmonic falls below 20kHz.
It is at -147.09-4.23= -151.32dBr though.
I tuned my APU notch for 997Hz and -30dB.
R
Rja4000
Liège, Belgium
I use an Y Cable
