Topping D900 DAC Review
Rate this DAC:
    Votes: 7 2.7%
    Votes: 14 5.4%
    Votes: 86 33.1%
    Votes: 153 58.8%
Maybe that is the reason the apparently new DAC was returned to begin with... I think the obvious was tried already, now it is up to support to handle the replacement or fix.
Yup! I've been in contact with them - they forwarded all of my testing data/results over to the engineering team. If they don't get back to me in the next week or so, I'll initiate a return to make sure I land inside my 30 day return window. I would prefer if they replaced the unit outright. I'm not interested in shipping the unit to/from mainland China when I've had it in my possession for two days.
Welp, while trying to get a cellphone video of the DAC glitching on audio, I discovered a pretty tight correlation between the glitches appearing at the start of a track, or shortly after I've done a forward/reverse seek in the song. Poking through MPD/ALSA docs, I uncovered the period_time and buffer_time settings. I left the buffer at 500ms, but changed the period from 125ms down to 25ms. That seems to have entirely fixed the audio glitches on 24bit depth tracks. The D900 is just very very twitchy compared to every other DAC I have at my disposal.
Code:
audio_output {
type            "alsa"
name            "Topping D900"
device          "hw:0,0"
mixer_type      "none"
auto_channels   "no"
auto_resample   "no"
auto_format     "no"
buffer_time     "500000"
period_time     "25000"
I've been waffling the entire weekend about actually keeping this device, though. The remote is fantastic; it has a solid milled aluminum case and it reliably controls the D900 - I can point it basically anywhere in the room in any direction and it "just works". The incredibly high output voltage is nice; I can leave my Buckeye 1ET6525SA on the lowest gain setting and still have more than enough power for my speakers. The relay-based volume control is also nice, with very satisfying clicks from the relays as you increase or decrease the volume.
The part that really scares me is that there are a lot of very bespoke circuits in this, with what I imagine are some fairly fiddly parts. This is outside of their normal products, which they seem to have really gotten down to a real science. All of their recent COTS parts high-end DACs seem to be very reliable, with nobody really talking about failures in them. Topping's after-sales support, along with the need to ship this item too/from China in the event of a problem, paints a bleak picture in the event that there is a hardware failure down the road. At this point I'm trying to weigh perceived reliability against the overall cost.
I like unique things, and the D900 feels relatively unique in this space at this price point. I'm curious where other people are on the reliability question.
I was initially annoyed by the D900, but decided to keep it anyway, after changing the environment around it.
For me the reasons to keep it:
1. very high SINAD
2. analog relay volume control which works
3. the fact that internal PCM to DSD conversion just works, with their own DAC design. No messing with filter settings.
4. much lower THD than ladder / NOS DAC's but with a similar time domain performance
I do combine this with the flagship mono's from apollonaudio
they drive a pair of Amphion Krypton3X in an acoustically controlled room.
Topping's store has a selection of used-like-new D900s for $1309. For those in the US, they're shipping from a US warehouse. They come with a 1 year warranty and the 30 day return window still applies.
$1800 was a hard sell - $1300 is a much easier pill to swallow.
Saw your post as I was researching the D900 and decided to order one since it has the 30 day return policy. Took all of a few hours for me to decide to keep it. For ~$1300 the D900 is a great value. Even at the $1800 MSRP it's still a better value (and better sounding) than any other DAC around that price. This isn't cheapo chi-fi budget sound. The DAC is a legit high end DAC. I'm not a mesurements guy, but rather go on what my ears hear, and my ears love this DAC. Topping really designed a winner with this one. Hard to believe it doesn't get more love from the audio enthusiasts out there.
Just wait till local gurus explain to you that your ears lie and all dacs sound the same :D:facepalm:
Sometimes it is just not worth the effort. You can spot the "ears only I don't want to be educated" types a mile off.
No one claims that all DACs are identical or sound the same—not even the owner of this forum.
However, many users completely lose sight of the fact that, with music recordings, we are dealing with absolute, unambiguous data—regardless of whether the source is analog or digital.
DACs and other devices can differ in terms of resolution—differences that almost always correlate with measured performance—but these variations are generally minor, barring defective units or exceptionally poor measurements.
Tonal differences always indicate an alteration of the original data, which points to a defect or a design flaw.
The only exception is equipment intentionally "voiced" for a specific sound, a feature the manufacturer would explicitly highlight.
On the "voicing" point - I don't really see how you can have both voicing and good measured performance.
If you've deliberately changed the sound, then you've changed frequency response, added distortion, or both.
Yet I'm not aware of any manufacturer claiming special voicing while also saying "yes - we did that by making the FR less accurate" or "we added audible distortion". The specs are always - flat and low.
You can't have it both ways—that’s clear.
I cite this as an exception because it isn't a defect or design flaw if the manufacturer explicitly points it out. However, very few manufacturers do this—often in the vacuum tube sector.
Reactions: MBO
Ah yes - where distortion and frequency response are notoriously .... let’s be kind and say "not SOTA"
So why not justify it by calling it "voicing"
:p
:p
I am not a native English speaker, so I find the distinction in English a bit difficult.
"Voicing" is probably exactly what I mean.
Sorry - I wasn't commenting on your post. I'm poking fun at the manufacturers trying to turn a defect (poor specs) into a benefit (calling them voicing), with precious little justification.
If you scroll up a couple of pages you will see a post about all the state of the art dacs sounding the same. Also, the same people told me that two specific dacs sound identical when I had both with me. But hey, who am I to say what I heard, right? :D
The set "state of the art dacs" is a subset of "all dacs"
I prefer the phrase "well measuring" or "measurably transparent" or just "transparent" (as a shortform) since you don't need SOTA for transparency to the human auditory system.
So - yes - no-one says "all dacs" sound the same. Many of us - with valid reasons - say two transparent dacs, must by definition sound the same**. What they output is audibly identical.
**you might perceive a difference in sighted listening, but if you have level matched the two devices accurately, then that difference is not in the sound-waves reaching your ears - it is created in the wetware between them, based on stuff that has nothing to do with the sound.
Did you really conduct these comparisons blind and with matched levels, or did you know which DAC was playing?
Strongly suggest adding a Gustard U26 DDC to D900 using IIS.
Then D900 will be in slave mode and using U26's precision OCXO,
And then you'll hear all what you didn't hear in your former years of listening to your favorite titles... :)
There will literally be zero audible difference in the sound waves reaching your ears.
Most likely there won't even be low level measurable differences in the electrical output from adding a DDC. No matter how the OCXO Is oiled with extract of snake.
