Topping D900 DAC Review
Rate this DAC:
    Votes: 5 2.1%
    Votes: 14 5.8%
    Votes: 83 34.3%
    Votes: 140 57.9%
This is a review and detailed measurements of the Topping D900 discrete "1-bit" balanced smart DAC with PEQ. It was sent to me by the company and costs US $1,799.
The D900 comes in the most prestigious clothing Topping uses. It gives a feeling of luxury which I like. Touch screen UI is provided for manipulation of setting (as well as a remote which I did not need to use). Back panel shows elimination of RCA output which I am totally fine with:
Topping-Balanced-High-End-DAC-Stereo-Discrete-1-Bit-XLR-DSD-R2R-back-panel-remote-bluetooth-Re...jpg
Instead, we get variable and fixed outputs. Dual optical and coax inputs are provided for those of you with many such inputs. Trigger is now standard seemingly on all Topping products which is much appreciated. It allows one button turn on of your entire system.
As specified, the incoming PCM samples are upsampled to one bit which can then be converted to analog using a simple low pass filter. Parametric EQ completes the picture.
Topping D900 DAC Measurements
The D900 benefited by the tune of 0.5 dB after a few minutes of warm up to produce some of the best noise+distortion numbers I have measured:
The D900 has copious amount of drive, going as high as 12.3 volts!
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR THD VS Level Measurments.png
This allows you to use your power amp at its lowest gain setting, boosting overall system signal to noise ratio. Speaking of that, the dynamic range is excellent:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR Dynamic Range Measurments.png
It goes up about 1 dB at max volume (not shown).
Multitone shows state of the art levels of distortion:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR Multitone Measurments.png
As well as with a 50 Hz signal into 600 ohm load, per stereophile protocol:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR Stereophile 50Hz Measurments.png
Slight error seen at very low amplitude in our IMD sweep:
But then becomes noise dominated and quite low at that.
We see the same small blemish in our linearity test:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR Linearity Measurments.png
The noise floor is extremely low and clean in jitter test:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR Jitter Measurments.png
Which then shows up a couple of inconsequential tones at -140 dB. The spikes on the left are part of the signal and are resolved incredibly well down to 24 bit LSB.
Filter attenuation is excellent:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR Filter Measurments.png
With the tiniest bit of droop at 20 kHz (0.2 dB):
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR Frequency Response Measurments.png
Wideband noise+distortion shows elevated levels considering what we have measured so far:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR THD VS Frequency Measurments.png
But that has an explanation in the form of ultrasonic noise shaping:
Topping Balanced High End DAC Stereo Discrete 1 Bit XLR 1KHz FFT Measurments.png
So not an audible concern.
As custom DAC implementations go, the D900 is the most perfect I have seen. It represents a heroic effort to near match state of the art, integrated DAC silicon. In other words, you get the buzzword of "discrete 1 bit" DAC with almost no penalty. Getting this level performance out of huge number of individual components is not easy and shows excellent engineering prowess.
Price is up there with respect to IC based solution. But is a "bargain" compared to high-end DACs with similar architecture but usually with worse performance.
I am going to recommend the Topping D900. If you want a custom DAC, this is it.
Hi,
If you ask me, that is indeed a nice device made for those you do not want to be like everybody else.
That originality has a price.
As far as I am concernend I don't see the point of spending that amount just to be different..
Regards.
Do I understand it correctly and it can natively play DSD without intermediate conversion?
Reactions: VQR
Very nice, but when I think about it... a) the price, b) no headphone amp included despite this price and c) I abstain from voting until it's clear whether there are no software/firmware antics like in the "famous" DX5 II.
Yes I am spoilt, we all are.
I still don’t see the point, but at least the esotericism doesn’t come at the cost of performance, only price.
For those not using a separate analog pre-amp, this can do the trick, no nasty surprises will come out of this.
Discrete or IC, that's a DAC, it seems it does what it should with no penalties.
Thanks Amir!
Thanks Amir. I've been looking forward to this test for a number of reasons.
It's 1 bit DAC, and I hoped the measurement might show some difference with delta sigma DACs, but they're all very similar indeed.
Topping's B100 has high dynamic range if you feed it a high level line input, and I wondered if the D900 was Topping's solution to that.
Topping's own (normally trustworthy) measurements show only slightly higher noise floor for the 13V output (so they're not simply waving it through as the same as 5V).
Topping's (A-wtd) DNR measurements are read off the APx555, and don't show any DNR advantage over the 5V output.
However although the 5V maths are consistent, 20log(13/1.6E-6)=138dB, and I guess I was secretly hoping this might have been the DAC to set a DNR record.
Ah well.
@amirm for such products with an analog attenuator, are you leaving it at unity gain and changing the output level with the generator or are you using the attenuator for some tests?
Dashboard says volume -2.0 dB so presumably he reduced the volume knob.
Thanks Amir!
Very true, but the problem is a D70/A70 or even E70/L70 combo can achieve pretty much the same end result.
This is a review and detailed measurements of the Topping D900 discreet "1-bit" balanced smart DAC with PEQ. It was sent to me by the company and costs US $1,799.
Sined well below it's archrival SMSL and double the price. Bad.
It's the optics too probably.
At 33 x 21 cm approaches full-size gear (about 10 cm short still) so can be used at traditional "audiophile" racks without looking tiny like the rest.
But it will take a lot whole more to reach that crowd.
You should qualify what "playing natively DSD without intermediate conversion" means. To the best of my knowledge, conversion from DSD to analogue was hardly ever made without signal processing of some sort since day one of this format. But if you means decimation of DSD to low sample rate PCM for the purpose of conversion to analogue, that is actually a very rare occurrence.
If you wonder what happens when the 10 bands parametric equalizer is used, that is an entirely different topic. If you intent to do some equalization on the audio pass-band directly on one bit data in the digital domain, you obviously end up with lengthier numbers than one bit, which is very very taxing for processing power. According to the relevant picture published on the Audiophonic webpage about the Topping D900, the parametric equalizer works only on PCM input up to 32 bits/192 kHz, if I understand it correctly:
So, no miracle indeed at this price point and silicon bill of material: no direct computing on one bit data can be performed in this DAC when the PEQ is to be used.
