may i ask if anyone has had issues doing the D90's firmware updating?
i read an owner's review that said it was very time consuming to go online and try to figure out what needed to be done and he had to jump through hoops to learn how to do it with his Windows pc.
i'm concerned because this process would ideally be a no-brainer, much like updating any Android cellphone's apps. i don't want to get all tangled up in spending hours upon hours trying to update this device. my gut tells me, but i may well be wrong, if this owner wasn't able to get good help from Topping themselves, that i wouldn't be able to get help from them either. i don't know though how good, for example, iFi's help would be in case their Neo had to be updated.
here's the quote from that owner's review:
You can only achieve MQA via a USB cable (I'd recommend buying a better cable than what Topping includes, Really Topping?)...
If you're new to music sources, MQA files, and how to get MQA results, it takes patience and study. This isn't quite "plug & play". Apos or Topping are not the best when it comes to support. I attribute this to audiophile equipment in these categories are niche and they don't have the staff resources or ability to provide great support? Fortunately, you can learn some via established YouTube reviewers.
The interface / handshake between your music source settings and device settings may take patience to set up, depending on what you use: Mac OS or Windows.
Topping sent a D90 MQA version V1.24 firmware update - oy. What a mess. VERY kludgy process. Again, some YouTube reviewers can help to a degree. All said, I love the results, sound, power, build quality, design but if this is your first entry into headphone amps & DACs, do so knowing it will take time to learn and utilize the system..."
All this fuss with firmware updating gives one unnecessary stomach acid.
