hmscott
- Joined
- May 17, 2020
- Messages
- 604
- Likes
- 493
@Dclone ****Update: The GPU noise is back. => A quick note, the Supra 0.7m cable got rid of the GPU compute "birdies". Yes, I'm surprised too - more testing, of course.That's great, I sure hope my new Supra 0.7m USB cable has the same effect on my USB noise. It's estimated to be delivered Monday, I'll report how it works next week after it arrives.
And, yes, there are audible improvements as well. <== at least this is still true.
Thanks guys for the Supra USB cable recommendation! It was worth a try!
****Update: The GPU noise is back. After I swapped in the new Supra USB cable I had swapped between a couple of GPU jobs in progress and there wasn't any noise, but now new jobs (as jobs complete new ones are downloaded) have brought back the noise. The GPU noise is louder. I don't have any Ferrite Cores to clip on the Supra cable, but I'll bet that's what it needs. I'm going to pull the RCA cables to stop the GPU noise and keep running the Supra cable. I'll see if I can get some Ferrite Cores to add to the Supra cable. I'll also swap back in the Tripp Lite cable at some point with the Ferrite Cores built in and see if the GPU noise sound level drops in volume back to where it was.
Update: I swapped back the Tripp Lite USB cable with two Ferrite Cores in the build, and the GPU noise isn't as loud. It could be normal variance of the compute task so I'll have to check again later after I get snap on Ferrite Cores for the Supra cable and I can A/B the noise with / without the Ferrite Cores.
