Cut-Throat
- Joined
- Feb 15, 2020
- Messages
- 117
- Likes
- 133
So, I am trying some DSD Sample Tracks and was wondering if PCM should be displaying here at this bit rate or something else?
Royalties are all that matters to MQA.
They used their marketing presence and influence to leach some money out of those who actually added value, like Roon and Oppo.
Here are my MQA views:
It is technically inferior to HD Audio and, when played without a decoder, is technically inferior to a CD.
- MQA 15 bit audio format is masquerading as HD Audio.
- MQA does not have the dynamic range of HD Audio.
- MQA does not have the sample rate of HD Audio.
- MQA may have some lossy inaudible ultra-sonic frequencies.
Conclusion: Subscribe to QOBUZ and not TIDAL and save money too
- Rich
Wait... So tidal mqa is worse than cd quality? I don't understand.. I thought it just was a way to compress lossless content and uncompress it while you are playing it.
It "unpacks" the data, uncompress make it sound like the result is still lossless but it's not. It's lossy like aac/mp3 etc, which is why MQA is pretty pointless when services like Amazon music HD will offer actual lossless files. I mean there will be fans and non-fans but I personally fail to see the point besides DRM revenue for the MQA guys.Wait... So tidal mqa is worse than cd quality? I don't understand.. I thought it just was a way to compress lossless content and uncompress it while you are playing it.
It appears you may be converting your DSD to PCM prior to sending it to the DAC. Check out this wiki from JRiver: https://wiki.jriver.com/index.php/DSDSo, I am trying some DSD Sample Tracks and was wondering if PCM should be displaying here at this bit rate or something else?
There's no “may” about it.It appears you may be converting your DSD to PCM prior to sending it to the DAC
A quote from the "Playback" section: "Once you have PCM, it will be 64bit @ 352.8 kHz for DSD, and 64bit @ 705.6 kHz for 2×DSD". A sample rate of 705.6kHz is PCM. If you want native DSD or DoP you'll need to change some settings in your software.
The DAC has very little to say on the subject. It can only interpret what it is fed by its source.I just wanted to make sure I had everything set up right with the DAC.
I think you are getting your “64s” & “32s” a bit out of context and confusing yourself as a result. When you are dealing with PCM, the DAC display will show a maximum of 768kHz PCM and the number of bits should be handled transparently by the audio application software. Anything above that will be a DSD sampling rate and is technically 1bit (as opposed to the 16, 24 or 32bit structure of PCM) but at a rather higher sampling rate, starting at 2.82MHz.64 bit? Any DAC can do 64 bit 705.6khz? All I see are 32 bit max
So i should drop tidal in your opinion? I thought streaming lossless content was a problem that mqa solved. You can stream losslsss content on amazon hd?It is compressed consuming dynamic range. When played without a "licensed" decoder, that data is lost.
All of this is unnecessary, I use QOBUZ that stream CD and HD quality audio with no compromises.
- Rich
Excellent, although I have to say that 4×DSD is total number-chasing nonsense!OK, Success ! My foray into DSD
I won't dispute that observation.I'd have to say that DSD alone is pretty much nonsense.
I thought the filter was more accurate as well. Also i have a "mqa decoder" in my dac, so it shouldn't lose the data right?
@Veri
