Oukkidoukki
- Joined
- Sep 6, 2018
- Messages
- 510
- Likes
- 244
So.... what about rme adi-2? Is this leedh better there too?.......and if the volume is full is it then as good as dac mode in d90?
I didn't hear the RME ADI-2 yet, but AFAIK there is no hardware volume control on it nor LeedH Processing too.So.... what about rme adi-2? Is this leedh better there too?.......and if the volume is full is it then as good as dac mode in d90?
any insight from your perspective would be helpful to educate those of us who just do this for a hobby.
But maybe I was wrongly informed here at ASR...
If you want actual answers based on the reality that we currently know of, @JohnYang1997 will be a better option.
sure, but John didn’t make the assertion.
I’ve A/B’d using a quality resistor-based pre and the D90 digital volume control, and I can’t hear any difference whatsoever.
Actually I did the same comparison (however not in a very scientific way) and could not decide which was the better way. So I use the D90 volume control and also with the advantage of remote control!sure, but John didn’t make the assertion.
The volume control is done inside the AK4499 chip (DATT in the block diagram), after I2S.Yes, when the volume is set to 100% in D90 or M500 (or every DAC which has simple digital volume control the given I2S signal entering the DAC chip is bit-perfect, so their SQ is the highest - but if it has option for disable the volume control that is the best way)
It seems a bit of a contradiction to me: on one hand you are looking for THE perfect volume control and on the other hand you are perfectly happy with lossy MQA. Probably the marketing guys got a grip on you!Are you kidding? The pre-amp mode is just a joke in the D90. It's a crappy standard digital way - I don't want to use that at all.
The Lumin's LeedH digital method is an ultimate version of the digital attenuators which doesn't causes any loss in dynamic range.
Unless it is Roon Ready (networked using RAAT) it makes no difference.Speaking of the pre-amp, anyone know if there's been any effort to get a Topping DAC Roon certified? AFAIK its just a matter of the manufacturer sending Roon a sample / Roon seeing if it can do what it needs to do to meet their spec and bang, you get a nice little Icon and possibly the ability for Roon to control the devices volume. Or else some required software changes to meet their spec.
At the very least, worth going through the trouble for their flagship DAC (D90). Would help distinguish it as a premium product.
then?proper volume control
Roon also enforces proper volume control.
For example, if analog volume is available it should be used.What's...
then?
True.I was under the vague impression that even USB DAC's could be certified to work with Roon Bridge. The HiFiBerry is certified, its just a sound card to the Pi, as long as the volume control can be done via the USB interface you'd imagine it should be doable.
True.
But Roon Device Volume does not even work with some DACs. Fixed or DSP volume must be used.
Ideally, it will controlled a relayed resistor ladder.
4. In DAC mode, pushing either of the volume buttons mutes / unmutes instead of doing nothing (for ability to rapidly turn off volume)1. There's no way to really tell if it's playing and my amp's are off. Not a huge deal.
2. My old audio lab dac allowed you to program a default input which it would return to after being power cycled.
3.With the D90 I need to scroll between multiple options to switch between the TV (optical) and the streamer (usb). Being able to disable inputs I don't use from the default list would mostly solve that.
D90 automatically sense 'digital' signal of optical or USB. For example, when i turn off streamer(USB), and i turn on TV/TV box/soundbar, it automatically swith from USB to Optical without remotely control or manual touch the button.3.With the D90 I need to scroll between multiple options to switch between the TV (optical) and the streamer (usb). Being able to disable inputs I don't use from the default list would mostly solve that.
