Thanks for sharing your personal opinion. Science requires verifiable data, otherwise called facts. Can you provide some?
Nothing that will satisfy you since you refuse to engage with the cassette analogy
The fact that cassette tapes (or vinyl, for that matter) have inferior dynamic range compared to 16 bit digital is irrelevant to the question of whether 24 bit digital in a reproduction application brings an additional audible difference, regardless of the genre.Nothing that will satisfy you since you refuse to engage with the cassette analogy
I’m not interested in “winning “. The name of this forum is Audio Science Review. If you’re not interested is exploring the science of audio you’re certainly in the wrong place. If you are interested, then welcome to the opportunity to examine your existing opinions in the light of new information that tests them.Convincing to someone who hasn't read the argument. You win, it's alllll in my head
Here are some resources that discuss the issue. But think of it this way: A properly recorded 16 bit signal has 96 dB of dynamic range. Your room and heart beat are surely at least 20 dB. So you'd have to be playing music peaking at 116 dB SPL to extract the last shred of a 1 dB signal above the noise floor. Not only can't your ears/brain hear that difference, your speakers in any residential room (or headphones) can't play that accurately while that loud. And, regarding classic masters, anything ever recorded on analogue has a noise floor far too high to have that low a signal.Of course I am interested. Let's put it this way - I don't know enough to debate you. You've told me I'm wrong - I accept it, I'm wrong, I can't hear a difference, I just think I can
But this is all good news: You really can obtain 16 bit playback better than you can physically experience. The bad news: You can hear the difference between good and bad mastering.
24bit vs 16bit, the myth exploded!
It seems to me that there is a lot of misunderstanding regarding what bit depth is and how it works in digital audio. This misunderstanding exists not only in the consumer and audiophile worlds but also in some education establishments and even some professionals. This misunderstanding comes...www.head-fi.org
16-bit... It really is enough!
Currently listening to the old 80s CD of Sting's Nothing Like the Sun. Fabulous recording and wonderful sounding CD. The CD has excellent dynamic range and even in the quietest parts, there's absolutely zero audible hiss. The basic point is that 16-bits provides massive dynamic range. Unless...www.audiosciencereview.com
Yes, 96 dB ABOVE BACKGROUND. You've confused maximum SPL and Dynamic Range. Most background is 30-40 dB. https://www.acousticsciences.com/asc-articles/auditorium-acoustics-104/ So classical at 108 dB SPL is about 78 dB above background. A full cymbal crash etc. heard in the audience could reach 125 dB. Unlikely you'll play that at home, but still, that about 95 dB on a recording. If you look at the full page you've linked to it states: "the human ear can accommodate a range of 120 dB or more though permanent hearing loss can occur with levels above 90 dB."Some science:
And when you turn up the volume at the quieter parts like I (and many people) like to do...
Practically, 16 bit gives 90dB dynamic range. That's a 20dB shortfall before volume adjustments
Pop music, 16 bit is fine. Some classical needs 24, some prog as well (basically classical music with new instruments and rock bent)
Thanks for the answer. Still, I don’t think you answered the second question. My question was if there’s a difference in sound when you use the Topping as a DAC vs DAC and preamp - no matter what is connected before it.The DMP & the Topping will sound the same. You don't tell us if you're doing volume control with the DMP or using an analog preamp. Let's assume you're doing the former.
1) On the Topping, the best output is XLR (balanced) output while on the DMP (in your setup), it's USB. The only exception would be if the source is too far from the DAC (outside of the USB standard cable lenght limit), in which case you'd use optical. Downside of optical: If DAC is slave clock.
2) For the DMP, if you use and external DAC, you'll be doing volume control in Digital, which is usually less desirable compared to high quality analog volume control. I'm not sure how the DMP does volume control but if it's high quality analog, i'd remove the Topping.
If Topping displays 192 KHz, it's just the bitrate of the incoming signal: The Topping can't do anything about that. The source (DMP-A6) just sends the bits it reads from file / stream.
Complete disagree and you don't seem to understand SPL & Dynamic range, background noise, hearing limitations, etc. Raising bit depth just lowers the noise floor and add dynamic range, nothing to do with "precision" or "it's not quite enough". And your cassette stuff is just hilarious: The distortion level is much higher, separation much lower, added noise, wow/flutter, etc etc etc. So of course difference is noticeable and a cassette is analog, not digital...Lol you assume I haven't done tests...
Pop music normalized to -1dB with the VU meter sitting at -12dB and the peak meter never dropping below -25dB, I agree 100%, 16 bit and 24 bit would be indistinguishable. Classical music, though, there's a difference, and it's not even that difficult to hear.
I'll add, you do need to be using very good equipment - it needs to be set up right, and also the listener needs a trained ear.
Take two people off the street and they can't even tell the difference between a violin and a viola, a clarinet and an oboe.
I don't really want to debate this - we'd argue forever:
"you shouldn't be able to"
"I can"
"I don't believe you, you shouldn't be able to"
"I can"
"I don't believe you"
I'd invite you over and demonstrate, but the likelihood of us being in the same general area is next to nil. Plus, depending on how one is invested in "you shouldn't be able to", you could easily deny the [small] difference.
Think about this for a second: in a classical song, after a crescendo a violin comes in - quietly, at -55dB. There is 35dB dynamic range left. This is worse than a cassette.
Can you tell the difference between a violin recorded at -3dB on 16 bit digital, and that same source signal recorded on a cassette at -3dB?
(the answer, if you're being honest, is yes. So for a realistic reproduction of an orchestra, 16 bit audio is not enough. Is it enough for a $300 mini-system? Yes. Is it good enough for a $1,000 Sears catalog stereo? Probably. Is it good enough for a $15k system in a treated room? Not quite.
For practical purposes, 16 bit is enough. For true high-fidelity reproduction, it's not quite enough.
I won't lose my time explaining again, these posts say it all...
Audio Bit Depth: Everything you need to know
Bit depth is all about noise, so how does more data affect the quality of your recording? Let SoundGuys explain.www.soundguys.com![]()
High bitrate audio is overkill: CD quality is still great
Eager to shell out a bunch of cash for hi-res audio? Save your cash, says Chris. The sample rate and bit depth of CD quality audio can outresolve the limits of your hearing.www.soundguys.com![]()
The great audio myth: why you don’t need that 32-bit DAC
There is a growing trend of shoving a 32-bit DAC into flagship smartphones, but this is nothing more than a marketing gimmick. Here is why.www.androidauthority.com
Monty did a very good job here:
D/A and A/D | Digital Show and Tell (Monty Montgomery @ xiph.org)
That's a very interesting question - and it should be a basic one. The effect is "masking".Is it your contention that someone playing brown or pink noise at 60dB with a 2kHz tone at 35dB, that the 2kHz tone would be... inaudible?
Disagree again. Human hearing has a practical limitation, 16 bits well recorded is already more than enough.You seem to misunderstand my position - I'll restate it: 16 bit audio is almost exclusively a limitation for recordings of classical music, especially more quietly recorded classical music, most notably when being played back louder than usual.
I've said 16 bit is fine for popular music
Topping E70 experiences this exact mode of failure.Something in the back of my mind fears the D70 somehow switching to DAC mode and blowing my speakers to smithereens due to the sudden shift to full output.
Update - so I missed the second graph on linear frequency response :0) I see the differences more clearly - and the rest of the tests don't relate to that anyway, so please forgive some of the clunkiness of my previous post.I can't seem to find which filter Amir is using for the majority of the tests - min phase or linear fast roll off?
I'm surprised that min phase F1 is the default. It isn't very clear on the initial graphs of the various filters which one would be considered most accurate.
Anyone have any preferences here?
