Topping D50s connections
EPIC
Hello All!! im new, english is not very good, but i try:)
A few days ago i got my d50s, and im happy with the ( thanks for review amirm) but i have a some question about connection.
First question: i try using my smartphone (mi9) with OTG cable connected to usb DAC, spotify/youtube playing-its ok, but trying to play some music from smartphone with music player mp3 or smth like that, no luck, no sound, trying differents players, like foobar, but no luck, its normal?
Second: I want a recommendation, how best to use spotify/tidal with this DAC for best sound quality, i like BT connection, so i cant use it, but i think USB connection is better, true? so one way i can use tablet+otg usb? and another way, i think about media streamer like ROKU/MI box S, to control application on TV, but then i must use TV optical cable to dac, witch way is more professional and more accurate to drive the speakers:) thanks all.
im using onkyo AMP 9010, d50s, smartTV, ELAC Debut 52 speakers.
raistlin65
Grand Rapids, MI
USB or optical for best connection. Take your pick.
Not sure what you mean with your first question.
Chrise36
Try using hiby player.Make sure the cable is true OTG first.Enable usb audio routing on the phone if it is disabled.
