Topping D50 III Balanced DAC with EQ Review
Rate this DAC:
    Votes: 11 2.4%
    Votes: 12 2.6%
    Votes: 63 13.6%
    Votes: 376 81.4%
Oh that's how it works? Haha thanks for the lesson! But the graph fluctuates at some point?
The fluctuation is Amir's audio analyzer switching input levels:
It's not the DAC.
No it’s a digital volume control.
But my point was this graph (light blue/orange is AutoRef on; blue/red with AutoRef off) :
Yes, and every kink in that line is a separate Analog attenuation stage.
That's what I meant with Analog and what I specifically excluded when I said that the D50 III performs like any other DAC with Digital volume control (= not Analog)
It's not the DAC.
I suddenly wondered about how to have the best "fidelity" when listening with very low volume :) so for my scenario, a good analog preamp would work? Well, I may not be able to tell the difference after all haha
If you can't hear any hiss currently, then buying a preamp will not improve fidelity.
I have taken a close look at how the volume control on the RME ADI-2/4 Pro works, and I hope my input will clarify the discussion a bit ;)
The volume setting at the ADI digitally reduces the level fed into the DAC chip, but it also controls several relays that can switch the gain within the analog output stage. So, it is a kind of hybrid volume control that operates in both the digital and analog domains.
In practice, "Auto Reference Level" works as follows:
1. The DAC is set to full volume:
- The DAC chip receives the bit-perfect digital signal.
- The analog output stages are set to full gain via the relays.
2. The volume is reduced slightly:
- The DAC chip receives a digitally attenuated signal.
- The analog output stages remain set to full gain via the relays.
3. The volume is reduced by 6 dB:
- The DAC chip again receives the bit-perfect digital signal.
- The analog output stages are switched to -6 dB via the relays.
4. The volume is reduced by slightly more than 6 dB:
- The analog amplifier stages remain set to -6 dB via the relays.
At -12 dB, the next stage is reached where the DAC chip is once again fully driven, and the relays switch to -12 dB attenuation. A third stage of analog attenuation occurs at -18 dB.
Beyond that point, only the input signal of the DAC chip is digitally attenuated, and the SINAD drops as expected.
The diagram shown here therefore actually displays the ADI's SINAD at various volume levels, not the analyzer's ranges!
If you disable Auto Reference Level, the SINAD drops immediately because no analog signal attenuation via the relays takes place as shown in the diagram.
The ADI’s hybrid volume control therefore combines digital volume adjustment with a three-stage analog gain switch using relays. This technique ensures that a high SINAD is maintained across a wide volume range, even when the device volume is lowered.
Consequently, with "Auto-Ref-Volume" enabled, the ADI’s volume control is preferable to digital volume control (such as that found in Roon). This is also the reason I offer the "rooADI" Roon extension, which allows you to adjust the ADI’s actual device volume directly using Roon’s volume slider.
Best DrCWO
Best DrCWO
Nice summary, but none of this should be news to anyone in this discussion.
The D50 III's kink in SINAD vs level is caused by the analyzer, not the DAC:
Topping D50 III Balanced Stereo DAC PEQ THD+N vs Level Measurements.png 1528516561604 (5) (1).png
It uses purely digital volume control and as such, adheres to the "1dB SINAD per 1dB volume" rule, just like all other competent DACs with digital volume.
In contrast, the ADI-2's kinks in SINAD vs level are caused by analog attenuation stages, which makes it a fundamentally different kind of product. It's a DAC + Pre.
(Though I would argue that this changes the UX not nearly as much as customers think. Likely not at all, and definitely not if there's no hiss even with Analog Ref level disabled)
Am I reading correctly the graph, Mode 3 is -3.7dB at 20Khz and starts rolling off high frequency as soon as 13Khz?
No that's definitely not how biquad works. Your graph proves it, that's exactly cramping, see how at higher sample rates the bell becomes symmetrical? Because the filter moves further up in the spectrum. The other bands in the lower part of the spectrum don't change shape at different sample rates because they don't interact with the decimator filter. So both Topping and RME are involved?
If you're referring to my plot in the post just above, that's Excel computing from the formula.
