Topping D50 III Balanced DAC with EQ Review
Rate this DAC:
    Votes: 11 2.4%
    Votes: 12 2.6%
    Votes: 63 13.7%
    Votes: 374 81.3%
Not really a dac question but a EQ one. I am confused about using roon EQ. Can I use roon Eq on each channel separately....I mostly sum my RTA measurements and start from there.
Thanks.
Applying PEQ to each individual channel is not possible with the D50 III. You will need the DX5 II, E50 II, DX1 II or their flagship units (DX9 Discrete, D900) to be able to do that.
Thanks.
if you can do it for each channel, that's better, but your measurements has to be for each as well
Thank you , my real question is can I use roon on each channel separately...something they call procedural eq I think?.
And how do I learn to do that... I find that the lack of a true manual for roon to be a real drawback.
Thank you
Thank you
Your Choice of llm will assist you.
I have a question to the owners of the device and to those who know: Can I fit in two TRS to XLR adapters like pic bellow or is there not enough space?
Unfortunately, that won't fit at all; the sockets are far too close together for that.
