Hi everyone,
I've been using the D50III for some time, as a high precision generator, for my tests. I've also been using a Cosmos ADCiso (grade 0 - the most linear, in mono mode) and its associated scaler for measurements of analog signal. And when I first measured the D50III, I got the feeling that it could do better than the 123dB SINAD I measured.
So I completed my measurement setup with the Cosmos APU that notches the test fundamental by 30dB, before entering the ADC for measurements (the ADCiso). This has the advantage to lower noise and distortion created in the ADC by the high level signal, exactly as an Audio Precision does. I use REW software to compensate for the 30dB notch (precision of 0.01dB).
And so find below the SINAD result of the Topping, with 5Vrms output, and volume down by -1.5dB as Amir did (bringing the output to 4.2Vrms). I also aligned the span to Amir's one, that is 10Hz to 22.4kHz, so a little more noise goes into the computing of the SIAND (I do 20Hz-20kHz usually). And here we go:
I overlaid the two channels, and the distortion is surprisingly similar to what Amir reported, left channel having a little more H3 than the right one.
On SINAD perspective, the D50III reached 126.2dB on right channel (dashboard shown above) and left one was at 125.9dB, and so that's an average of
126dB SINAD!
It is a little complex to explain, but this is best case scenario for my little measurement setup. Thing is that the output level of the D50III must match an ideal input sensitivity/gain of the Cosmos setup for the highest precision. This is the reason to use the scaler that can increase the input signal in the comfort zone of the ADC for measurement with the highest resolution. And that is exactly the same with the Audio Precision that uses an auto-scaler (very useful for DR calculation).
Anyways, and obviously, with 4.2Vrms sine tone to measure, I'm right in the ideal, most precise measurement zone of my measurement gears. This might explain why the AP does not show as good result, simply because, if I remember, its comfort zone is around 5Vrms input, not 4Vrms.
The takeaway for end users is that the D50III is SOTA, but you knew that already.
