Topping D50 III Balanced DAC with EQ Review
Rate this DAC:
    Votes: 11 2.4%
    Votes: 12 2.6%
    Votes: 63 13.8%
    Votes: 371 81.2%
Mine seems to have issues now.
it seems to go into a coma when it enters sleep on rare occasions(not that rare) and not wake back up, I have to unplug the power leads and plug them back in.
still works fine other than that so far though...
I think it''s about a year old, I could probably "fix it" by not having the power USB connected to my monitor, which switches of when I turn the monitor off..
but it's not something that happened any time till recently, mines probably 1+ years old now.
been in the same setup the whole time...
anyone else had issues? maybe 1.39 started it but I never noticed till now.
The USB-only PEQ on the D50 II is pretty much useless regardless of the bugs, but that doesn't discount this DAC was and still is the cheapest balanced DAC for perfect objective performance, a perfect BT implementation and incredible build quality.
Perfect for desktop pc users though,, and has a nice remote to change the volume.
Why "useless" ? USB is by far the best interface for a DAC...
Useless because most USB Host devices can apply PEQ internally already.
Hardware PEQ like what's built into the D50III has the most value with SPDIF input since SPDIF sources like CD Players, TVs, consoles have basic 3-band GEQ at most, more frequently nothing at all.
PEQ doesn't have a great value whatever the input anyway. DSP for room EQ'ing (after measurement with REW or similar) would be great.
PEQ is perfectly fine for room EQ.
PEQ is what WiiM use for RoomFit on the WiiM Amp/WiiM Ultra.
Parametric equalization (PEQ) is digital signal processing (DSP). It can be used for room correction. I do this on my D50 III with REW.
Quantify most. None of the i-devices can, and there are quite a few of them out there.
Yes, I got mine for use with a Macbook. I would also point out that the gaming consoles also have USB output without parametric EQ.
PEQ is readily available on macOS.
For example SoundSource or eqMac.
I totally have no luck this week... First I bought Hifiman headphones with non-working left channel. Today arrived a package with the D50 III... which is dead. Only the backlight turns on slightly, and that's it. :facepalm:
Dumb question but did you try the power button after plugging it in? Only saying this as that screen is always lit when the DAC is connected to power, even when the unit is off or in standby.
In standby it has a small dot in one corner.
Sure :D With a button, with a remote and I try to power it with 3 different cables and power supplies and still nothing ;D
EDIT:
OK, it turns out that the screen just isn't working, because through trial and error I managed to set the correct source and the sound is working. :p However, I'll still replace it.
EDIT:
Maybe you’ve received by error the prototype of a new pure-audio, screenless, D50-III-Lite? :D
EDIT:
Sorry to hear that you got a defective unit -- hopefully the retailer will replace it without any trouble. It's really quite a good DAC, FWiW.
Well, it's better than nothing and it depends on how much available filters it has. Full blow DSP is what really makes the job for room EQ.
